-   -   Liquid problem (http://forums.pelicanparts.com/off-topic-discussions/439457-liquid-problem.html)
M.D. Holloway 11-06-2008 07:51 AM
Originally Posted by sammyg2 (Post 4285953)
You find yourself in a room with a door on either end. One door leads to freedom, the other to sure death.
In front of each the doors is a guard. The guards will not stop you from going out which ever door you choose.
One guard always tells the truth, the other always lies. You allowed to ask one of the guards one question and one question only.
How do you get out safely?
If the guard isn;t goona stop me why is he there? Thats would just piss me off so I would push a guard out one door - if he dies, I go through the other door.
DARISC 11-06-2008 10:11 AM
I'd ask one of the guards what door the other guard would say leads to freedom, then I'd go out the other one.
DARISC 11-06-2008 10:30 AM
Originally Posted by sammyg2 (Post 4285974)
You find yourself at the foot of a flight of stairs.
Next to you are three switches.
One of them turns on an incadescent light bulb in a room at the top of the stairs, but you can't see the light or any light from it unless you climb to the top of the stairs.
You need to determine which of the three switchs turns on the light but you are only allowed to climb the stairs one time.
How do you do it?
I'd flip on a switch and wait for a couple of minutes.
Then I'd flip it back off and flip on another switch and wait for about another 30 seconds.
Then I'd flip that switch off also and run up the stairs and into the room.
Then I'd touch the bulb to see if it was hot.
If it was hot, that would tell me that it was controlled by the first switch I flipped.
If it was warm, that would tell me that it was controlled by the second switch I flipped.
If it was cold, it's controlled by the switch that I didn't flip.
I was in this predicament when I was in Vegas last year. My biggest fear was that I'd run up the stairs and some character named Tabs would jump into the doorway and push me back down.
sammyg2 11-06-2008 11:12 AM
Bingo. A positive times a negative is always negative. Involve both guards and you know that whatever answer you get is wrong.
sammyg2 11-06-2008 11:14 AM
Two for two.
The key was incandescent.
If it was fluorescent it wouldn't get hot enough to use temperature as an idicator.
