98 Tahoe wiring help
My power door locks don't work ( any of them) I've checked all the fuses, it looks like there's a relay in the circuit somewhere but I can't seem to find it.. Any suggestions ? I've checked all of the fuse/ relay boxes that I can find,,
Thanks Todd |
It's possible there could be a broken wire in the harness in the rubber boot where it passes through the door to the switch.
Todd, there is a door lock relay under the center of the dash. It has six wires, ORANGE, TAN, WHITE, LT BLUE, GREY, and BLACK.
Orange: is constant hot. Tan: goes to terminal "A" on all of the lock actuators. White: goes to the unlock terminals on each door switch, and also to terminal "D" on the door lock control module (Front of Left Rear Wheelhouse). Lt Blue: goes to the lock terminal on the door switches, and terminal "C" on the lock module. Grey: Goes to the "B" terminal on the lock actuators. Black: is ground. The orange wire runs to a constant hot, 30A fuse, PWR ACCY / CB , in the instrument panel fuse block (left hand side of the dash). I can try to send you a schematic if you want, it might be too small to use though. |
Thanks Shaun,, I was on GMtruck.com but it sucked... Damn you can really appreciate this forum with the amount of inactivity on the others..
LM6,, I have the schematic thanks,, and just found the relay with the info Shaun gave me. I'll figure it out tomorrow in the light..
Todd, you back here for Thanksgiving?
I am, should be getting into Manch the Friday before and hanging out till Tue after.. let's get together!
-Chris |
T |
Ok guys, I picked up a new door lock relay and no luck.. Here's a wiring diagram.. I have 12 volts on the orange to the relay ( it's a 4 door so look at the relay on the right).. When I short the orange to the tan or light blue it does activate the door locks).. I don't get a full short on the black to ground conductivity check. So now where do I look for a broken wire?? I'm thinking maybe the black wire?? Suggestions ?http://forums.pelicanparts.com/uploa...1226257091.jpg
Hey Todd,
Do you have 12V on the other orange (to the door lock switches)No power there would cause a no go condition. Using a meter, are you grounding on the chassis, or grounding on the black wire on the relay? By trying both ways, you can tell if your black is broken. Orange --> meter --> chassis = 12V Orange --> meter --> black wire = ?? On the output of the switches (coming into the relay) do you see 12V??? |
Charles, yes 12 on the orange, I'll make some measurments tomorrow and comment.., thank Nicole for letting you look at this for me
| All times are GMT -8. The time now is 07:40 AM. |
