-   -   HVLP Virgin/Help (http://forums.pelicanparts.com/off-topic-discussions/442826-hvlp-virgin-help.html)
Robert Coats 11-23-2008 04:18 PM
HVLP Virgin/Help
I have a HVLP gun I've never used, but would like to start. Some good information at this thread (http://forums.pelicanparts.com/porsche-911-technical-forum/7903-hvlp-paint-guns-pro-any-cons.html?highlight=hvlp) but I have a few more specific questions.
(1) I want to paint some wood and metal fixtures. The wood is bare plywood, and the metal is sheet metal with a semi-gloss paint on it already. After a good sanding and cleaning of dust, what other prep is necessary?
(2) Can the same paint and primer be used for both bare wood and (already painted) metal?
(3) I understand automotive-type paints are really expensive. I would be happy with just some standard, plain/simple colors to start. What exact kinds of paint and primer are a good choice for HVLP work?
(4) How much to buy? The initial project's painted area is probably equal to about a half-sheet of plywood.
(5) I assume you have to thin the paint/primer to get it thin enough to flow through the HVLP gun? How do you do this? Is there a ratio/rule-of-thumb?
(6) The final finish needs to be high-gloss. What is the suggested lacquer to use for HVLP? Does it need to be thinned like the paint/primer, or what?
(7) What is the thinking about ambient temp? How cold is "too cold" to get good results from an HVLP gun?
