-   -   IT - Hardware help please - 2nd drive IDE to SATA on SATA Mboard (http://forums.pelicanparts.com/off-topic-discussions/444994-hardware-help-please-2nd-drive-ide-sata-sata-mboard.html)
MotoSook 12-06-2008 09:00 PM
Yes, Dave. I'm in the old drive trying to open the "User" folder. "Administrator" and "All User" folders are accessible, but not "User" where all my data resides.
slodave 12-06-2008 09:06 PM
1. Launch Windows Explorer or My Computer.
2. Click on the Tools at the menu bar, then click on Folder Options.
3. Click on View tab.
4. In the Advanced Settings section at the bottom of the list, uncheck and unselect (clear the tick) on the “Use simple file sharing (Recommended)” check box.
5. Click OK.
Do the above, then see if the security tab shows up, if so, try my other instructions.
MotoSook 12-06-2008 09:18 PM
I was able to do the above and was able to open the User folder, but sub-folders are locked and I can't use the same method to unlock them.
slodave 12-06-2008 09:22 PM
That's what I thought. Get back to the security tab as before....
At the bottom right, you will see a tab called Advanced, click it...
Add Everyone again... Check Full Control, wait then see if you get access...
MotoSook 12-06-2008 09:29 PM
It's going to take me all night to do that to every subfolder and file....no other way huh?
slodave 12-06-2008 09:32 PM
No, only on the "User" folder. It should then apply to all sub folders/files.
MotoSook 12-06-2008 09:33 PM
I must be doing something wrong. It did not apply to sub folders and files.
slodave 12-06-2008 09:37 PM
Is the user "System" there? Also after you added Everyone, what did it say above Full Control? Make sure it says Apply onto: This Folder, subfolders, files.
MotoSook 12-06-2008 09:43 PM
In the Advance window of the security setting, it lists full permission for everyone (System is there too). "Inherited From" = not inherited. "Apply to" = "This folder, subfolder and files"
I figured that was right...but no entry to sub folders unless I manually unlock them like earlier.
slodave 12-06-2008 09:59 PM
This link should do it:
http://www.z-a-recovery.com/art-recover-userprofile.htm
Start from step 3.
MotoSook 12-06-2008 10:04 PM
I'll give a shot..if not, I'm hitting the sack. It's midnight here....I'll get back on it tomorrow.
Thanks for all your help, Dave. I hope you feel better.
MotoSook 12-06-2008 10:27 PM
YES! Yes!
It worked, Dave. It took a while to change ownership of all the files, but it worked!
Thank you so much for your time and patience. If there's anything I can do for you....don't be afraid to ask.
slodave 12-06-2008 10:28 PM
You are very welcome. I always forget about this issue. It doesn't always come up.
