ReCalibrate Your Mouse for '09
MOUSE CALIBRATION
You should actually do this every year. Even more often is recommended by computer gurus if you spend a lot of time on the computer.
I was shocked to see how well this works, and how far off mine was!
To re-calibrate your mouse, click and hold on the Y below, then drag the Y toward the g.
If it doesn't work immediately, you might want to clean your mouse, as the calibration is off.
You idiots. You'll believe anything
I'M SURE YOU WILL ALSO RECOMMEND THIS TO ALL YOUR FRIENDS ONCE YOU SEE HOW MUCH SMOOTHER AND BETTER THE MOUSE WORKS AFTER BEING CALIBRATED! AMAZING..
Old 12-25-2008, 10:18 PM
1.367m later
KevinP73's Avatar
Send a message via Yahoo to KevinP73
Great!! Thanks for reminding me. I forgot last year and this thing hasn't worked right all year. Any ideas where I can get a keyboard update download?
non velox ad propitiare, verisimile non oblivisci
If it's not The Original Automotive Innovations and Restoration, then it's just hot AIR.
Old 12-26-2008, 08:49 AM
Wickd89's Avatar
I just upgraded my power cord (the regular part that plugs in).
Good idea to do every year as well.
The insulation does wear out and it is better to be safe than sorry..
Next is i replace all the little screws on my laptop and then I can consider my laptop as having completed its annual refurbishment. ;-)
Luis "once was - Wickd89"
Carrera 3.2 - "Faster, Stronger, Better"
-- 2008 Toyota Camry SE V6 (mine)
-- 2005 Toyota Sienna (hers)
-- 1989 911 Carrera Cabriolet -SOLD
Old 12-26-2008, 08:54 AM
Unregistered
sammyg2's Avatar
I need to upgrade my computer's cup holder. It seems too flimsy to hold a large beverage.
Old 12-26-2008, 09:05 AM
Zeke's Avatar
My flat screen has to be re-flattened every so often. And I can't keep my hard drive as hard or as long as I used to.
Old 12-26-2008, 10:56 AM
78 in a '71
mossguy's Avatar
Milt - your hard drive may not improve over the next ten years. Just sayin'.
Best,
Tom
On glide path......
1971 911 T Targa
2013 Ford Fusion Titanium AWD
Old 12-26-2008, 11:22 AM
billyboy's Avatar
These are all good annual maintenance suggestions along with re-polishing your muffler bearings, and tightening the nuts that are attached to your joystick.
'68 911 2.2 "E" PMO Carbs, Electromotive Crankfire Ignition, Adjustable Spring Plates, turbo tie rods, Bilsteins, headers, MB911 muffler...
"The sea merely lies in wait for the innocent but it stalks the unwary."
Old 12-26-2008, 11:32 AM
least common denominator
scottmandue's Avatar
Hey look there are windows updates ready to be installed
Whoopie!
And look what I got for Christmas!
Also don't forget to clean your mouse balls!
Gary Fisher 29er
2019 Kia Stinger 2.0t gone
1995 Miata Sold
1984 944 Sold
Zeke's Avatar
Best,
Tom
Yep, and my volume control seems to be out of whack lately.
Old 12-26-2008, 11:48 AM
