MBruns for President
Whoa there - she's a little tight...
![]() ![]() ![]() ![]() Steady as you go...
Current Whip: - 2003 996 Twin Turbo - 39K miles - Lapis Blue/Grey Past: 1974 IROC (3.6) , 1987 Cabriolet (3.4) , 1990 C2 Targa, 1989 S2 |
where the hell is that?
Used Up User
The Corinth Canal - Greece.
Nero started work on it . . . ![]() Ian
'87 Carrera Cab ----- “Only two things are infinite, the universe and human stupidity, and I'm not sure about the former.” A. Einstein ----- |
That is awesome! I have seen video and pictures of it before, I have never seen it in person, I have been through the Panama and Suez though. That canal really improved the trade routes in the region.
A nose heavy airplane flies poorly, a tail heavy plane flies once. |
Hope no one else is comming toward you, because it a B!TCH to try and backup.
LOL |
Run smooth, run fast
Wow... very cool.
From Wiki: The canal is 6.3 kilometres in length and was built between 1881 and 1893. The Corinth Canal is considered a great technical achievement for its time. It saves the 400 kilometres long journey around the Peloponnesus for smaller ships, but since it is only 21 metres wide it is too narrow for modern ocean freighters. The canal is nowadays mostly used by tourist ships; 11,000 ships per year travel through the waterway. The water in the canal is 8 metres deep. At each end of the canal, seashore roads cross using submersible bridges that are lowered to the canal bottom to allow maritime traffic to pass. The canal was cut through heavily faulted sedimentary rock in an active seismic zone. Between 1893 and 1940, it was closed a total of four years for maintenance and to stabilize the walls. In 1923 alone, 41,000 cubic meters of material fell into the canal, which required two years to clear it out.
- John "We had a band powerful enough to turn goat piss into gasoline." |
Green Skull 006
I went through there in the early 70's - not for the claustrophobic.
S Reg 823 R Gruppe 246 1955 pre-A Carrera Speedster...x 1974 leichtbau..."Sascha" "It makes me sad. Our cars were meant to be driven, not polished" - Ferry Porsche while surveying a PCA Parade concours field. |
durn for'ner
Been there too. Almost surrealistic view from the bottom. Cool pics!
Markus Resident Fluffer Carrera '85 |
THE IRONMAN
I used to know a girl with the same specifications.....!
1984 911 CARRERA RUBY RED TARGA SW CHIPPED-BURSCH CATBYPASS MONTY FREE FLOW EXHAUST <IN GAS WE TRUST> |
Canal
and now if they dig a hole in the ground, you need 100 permit's, technical studies and 50 engineers to tell you how to hold a shovel.
wonder how much it would cost in todays $$$$ and how long it would take from idea to finished canal. |
THE IRONMAN
