Polishing intake and a Dremel?
Posting in OT because the car really doesnt matter and I know there is more experience out here.
Thinking about polishing the aluminum intake on my 944. Would a dremel do the trick of knocking down the major rough or will i need something more serious?
I want it to look like this:
photo courtesy: JoshB
Looking at this dremel kit.
http://www.amazon.com/Dremel-3956-02-MultiPro-Variable-Accessories/dp/B00006JSPB/ref=pd_cp_hi_1?pf_rd_p=413863601&pf_rd_s=center-41&pf_rd_t=201&pf_rd_i=B0002QZ1P6&pf_rd_m=ATVPDKIKX0DER&pf_rd_r=0174NPVK3MYJM2JHAQ64
I realize I would need to buy some more polishing type wheels as I get closer to the end.
Old 03-03-2009, 09:53 PM
Banned
m21sniper's Avatar
All you need to get to that result is a LOT of time and polishing pads.
Old 03-03-2009, 09:54 PM
I was wondering if the polish setups on the dremel would expedite the process any though.
Old 03-03-2009, 09:56 PM
slodave's Avatar
You know how small a Dremel is, right? Far easier to get a polishing equipment for the Rigid drill....
Old 03-03-2009, 09:59 PM
Hmm... Wonder what kind of polishing setups I could get for a drill.... Chuck it up in an air drill so I have a more variable speed.
The Dremel would get down it those small areas way better fwiw
Old 03-03-2009, 10:03 PM
slodave's Avatar
These are for woodturing, but will work and fit in most chucks.
http://www.woodturnerscatalog.com/store/Finishing___Buffing?Args=
I use them on the lathe to polish wood bowls.
Old 03-03-2009, 10:05 PM
Ok well first off I will need to start with something rough oh 80 grit should work. I am trying to find a way to save some time on that step. The buff isnt a big deal I will just borrow my dads old Black and Decker Buffer. Here is a pic for reference of what I am starting with.
The intake is a pretty rough cast aluminum to start with.
Old 03-03-2009, 10:14 PM
slodave's Avatar
http://www.woodturnerscatalog.com/store/Abrasives?Args=
Old 03-03-2009, 10:25 PM
Ok Duh. Thanks for putting up with me....
Old 03-03-2009, 10:31 PM
Banned
m21sniper's Avatar
An air powered angle head die grinder with polishing pads works great.
Old 03-03-2009, 10:37 PM
slodave's Avatar
The abrasive pads are a stiff foam an conform to different angles.
The Dremel won't work very well. Too small and no flexibility.
Old 03-03-2009, 10:39 PM
I didn't get much thermodynamics during my (short) stay in college but won't polishing it increase the operating temperature of the intake?
And maybe painting it flat black make it slightly cooler?
But I understand how a vehicle looks has value also.
Jim
down to jap bikes that run and a dead Norton
Old 03-04-2009, 03:14 AM
David's Avatar
+1. Start with sanding disks, move to 3M abrasive pads, and finish with a buffing wheel and polish.
Old 03-04-2009, 08:03 AM
Cars & Coffee Killer
legion's Avatar
I'm going to be that guy.
I'd just get one of the Lindsey Racing intake manifolds, which you can get chromed. They eliminate the restrictive airflow to the back cylinders that exist with the stock intake manifold when you run more than stock boost.
5 liters of VVT fury now
-Chris
Old 03-04-2009, 08:51 AM
Well I don't have a turbo so a Lindsey manifold and more boost make no difference to me. Besides labor is free. I was just looking for a way to use less of it.
Old 03-04-2009, 07:13 PM
It will take you 20yrs to polish that with a dremel. You need several different grits to get aluminum to a polished state. It's hard, dirty work. I did it to some rims and I wont do it again. Mag masters does a good job (but bad customer service)
I would search google for how to videos
heres eastwoods product page
http://www.eastwoodco.com/jump.jsp?itemType=CATEGORY&itemID=432
Old 03-04-2009, 07:46 PM
