? bitmap .bmp moving pics ? how to post
I receive these files in OE & O e-mails
If I hit "save as" it shows a .bmp file
it's a moving pic that I can't post here because I don't know how.
I've seen them posted here on pelican.
Does anyone know how to do it?
thx
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 03-12-2009, 11:28 AM
animated bmp files are a bit rare. Animated Gifs are more common. There should be a way to save the file as an animated gif which will upload (think animated avatars)
Old 03-12-2009, 11:30 AM
Canadian Member
911Rob's Avatar
the ones posted here are saved as ***.gif files from what I know.
It is difficult to change these types of files, if you can't save as GIF, then you're likely outa luck?
Rob McKibbon
Arena Red 96 993 TT LINK
Contemplate YOUR Success!
I went to www.download.com and searched "convert .bmp to .gif" and many programs popped up.
not excatly clear on if they'll help or not?
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 03-12-2009, 12:14 PM
I doubt it. It's unlikely that if you save in .bmp format that you'll retain the animation. Animation is not something that a bmp normally does, so when you save a gif as a bmp it'll probably flatten the image. Once you convert it back, the stack of frames will probably be lost. The only animated bmp files that I've ever seen are the startup and shutdown screens for Windows 98 - 95 and maybe 2000.
If this is something you can do, you could try sending me one of the emails with the image and I'll see if I can extract the image.
pm me if you want.
Old 03-12-2009, 03:39 PM
craigster59's Avatar
With bitmap files, I've just right clicked on "rename" and change XXX.bmp to XXX.jpg. Works for me.
Old 03-12-2009, 04:03 PM
Worth a shot, but if you try that with an animated image, change it to .gif. jpgs don't do animation.
Old 03-12-2009, 04:05 PM
ok.
I just sent you a pelican e-mail so you can "reply" and then I'll be able to send you the .bmp file
thx Steve
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 03-12-2009, 04:45 PM
