-   -   Opposing piston engine (http://forums.pelicanparts.com/off-topic-discussions/462688-opposing-piston-engine.html)
m21sniper 03-13-2009 04:50 PM
http://engineeringtv.com/blogs/etv/archive/2008/07/01/opposed-piston-opposed-cylinder-engine.aspx
Very cool. New type of piston engine.
Zeke 03-13-2009 05:02 PM
The CEO said 40% efficiency? Is that gonna work in the long run? The second chap said 3 HP per cu. foot? I hope he meant per cu in. ;)
TheMentat 03-13-2009 05:19 PM
gotta love the first question from the reporter after a rather technical description:
"sooo you have one cylinder for two pistons, right?"
:D
Jared at Pelican Parts 03-13-2009 06:03 PM
Junkers tried this with a 2 stroke diesel engine in the 40's
red-beard 03-13-2009 06:05 PM
My former company has 2 compressor designs which has horizontal opposed cylinders, to reduce the force couple. It used a 3 rod design, of which 2 were split. They were considering going to a 4 rod, double split design, so that more of the parts would be common.
The real savings is in the foundation for a compressor, since you don't have to deal with that force couple from the offset crank. It would also help in a car engine, with the reduction in weight of the block and in the less vibration transmitted to the frame. I'm not sure why they think the design would be 40% thermally efficient.
porsche4life 03-13-2009 06:07 PM
Looks like a cool idea if they can keep it funded and get it more maistream. Add some fins to that baby and make an aircooled Diesel!
cgarr 03-13-2009 06:16 PM
I still don't like engines whos parts have to stop and change directions.
Jeff Higgins 03-13-2009 06:29 PM
I believe Fairbanks-Morse had an opposed piston, two cycle diesel locomotive engine back in the '50's.
TimT 03-13-2009 06:34 PM
Really?
Like a two stroke or a four stoke engine where the pistons instantaneously change direction? The piston reaches apogee, then changes direction at some point the pistons motion did stop... even if for micro seconds..
Flywheels and multiple cylinders smooth things out..
TimT 03-13-2009 06:36 PM
I have seen that... I also seem to remember some tri engine with opposed pistons... may have been a marine app.. drawing a big crs blank now
RWebb 03-13-2009 07:07 PM
"extremely lightweight"
yes!
cgarr 03-13-2009 07:28 PM
This is the one I like::
http://www.animatedengines.com/img/gnome.gif
Mr.Puff 03-13-2009 08:36 PM
http://www.rotoblock.com/howitworks.shtml
ROTOBLOCK FTW!
m21sniper 03-13-2009 08:47 PM
Yeah, he meant per CID. :-P
Porsche-O-Phile 03-13-2009 09:12 PM
Internal combustion engine efficiency is WAY less than 40% today.
Pazuzu 03-14-2009 07:29 AM
The RX-7 fanbois call them "boingers".
For pure simplicity, adaptability, and power per pound, you don't get more better than a rotary turbo. Want more power? Add a rotor.
Or...go newfangled:
http://auto.howstuffworks.com/quasiturbine.htm
sammyg2 03-14-2009 08:03 AM
I wonder how they are going to deal with the unburned fuel and cylinder lube in the exhaust, which is why the 2 stroke died in the first place?
red-beard 03-14-2009 09:07 AM
HP per pound, it is hard to beat a turbine. Making a turbine work well in a car is another matter.
But then again, on a thurst per lb of weight basis, it's hard to beat a ram jet!
RWebb 03-14-2009 02:18 PM
yeh
I also wonder about those super long conn. rods on the outboard pistons...
well, we'll see what happens with it
afterburn 549 03-14-2009 04:50 PM
Dodge tried in a Monaco about 1966........guess it worked out not LOL
At least they tried
