-   -   Starting Or Deep Cycle Battery? (http://forums.pelicanparts.com/off-topic-discussions/464362-starting-deep-cycle-battery.html)
jyl 03-21-2009 07:36 PM
Suppose you have a car that is not driven for significant periods, not meaning long term storage but let's say the car sits idle for three weeks to three months at a time. Long enough for the battery to sometimes go flat. Would it make sense to install a deep cycle battery, so that repeatedly going flat doesn't mean buying a new battery? Can deep cycle batteries be used as starting batteries with no problems?
DasBoot 03-21-2009 07:42 PM
Yes, but they take longer to charge. So, firing up the car for a few minutes every week ain't gonna do it. Why not get a battery-tender?
azasadny 03-24-2009 08:29 AM
Optima red-top paired with a C-Tech charger.
Neilk 03-24-2009 10:14 AM
I think I killed my second Optima in 2 years by not driving the car enough. I think will buy the C-Tech charger if that really does the trick.
Is the trickle charger the only way to keep an Optima battery alive if you don't drive your car enough?
Tishabet 03-24-2009 10:29 AM
I use a battery tender (the "smart" kind that does not overcharge) on my Buick, which gets parked from October to April... works great.
David 03-24-2009 10:34 AM
Battery tender. I have them for the 930 and both bikes. On the 930 the little plug hangs out the front spoiler for easy connnection.
masraum 03-24-2009 10:37 AM
Yeah, wouldn't one of those smart trickle chargers be a better answer?
jyl 03-24-2009 12:21 PM
A trickle charger would clearly be the best thing to do, but my garage is miniscule, will hold a 911 and a thimble but not both. Sometimes the 911 ends up parked on the street for a week, which stretches to two, and three, and . . . shouldn't happen but it does. I am experimenting with a solar trickle charger now.
Mo_Gearhead 03-24-2009 03:33 PM
I certainly do not know how the internals (guts) differ on a standard battery vs deep cycle. But the ONLY application I was aware of for a 'deep cycle' battery is for trolling motors and lighting in boats?
My though has always been they are designed for low amperage draw over LONG periods of time, (slow draw-down).
In fact most fishing boats have deep cycle batteries for just such applications, and a standard battery for starting the engine ...don't they?
I don't think they are designed (internals) for large, instant current draws.
...but I may be wrong.
porsche4life 03-24-2009 04:24 PM
Dont you own an extension cord?
KFC911 03-24-2009 04:38 PM
Originally Posted by Mo_Gearhead (Post 4565133)
I certainly do not know how the internals (guts) differ on a standard battery vs deep cycle. But the ONLY application I was aware of for a 'deep cycle' battery is for trolling motors and lighting in boats?...
I've been using the Optima Blue tops on my bass boat for a long time. I've got a humongous blue top as my primary trolling battery, and a very old (but still good) smaller blue top as a second trolling battery (for 24V turbo trolling). When my boat cranking battery died a few years ago (I'd always used "regular" batterys for that one), I purchased a smaller Optima Blue top "dual purpose" deep cycle and cranking battery and it seems like it might be perfect for a 911. I might be wrong, but I always thought trolling batteries could be depleted (I know I have many times), but it was important to charge them back at the end of the day (I always have). I now keep Battery Tenders on them so I never let them discharge and sit for long periods of time.
