-   -   Home-made Push Rods? (http://forums.pelicanparts.com/off-topic-discussions/465763-home-made-push-rods.html)
Porsche_monkey 03-28-2009 01:52 PM
I am rebuilding an old engine that is missing a few push rods. I need two 5/16" diameter push rods about 14" long. I can still buy valves and pistons, but push rods are NLA.
Anyone know where I can order some push rod tubing (4140?) to make my own? I can make the hardened inserts, I just need tubing.
Or, has anyone ever replaced a tubular push-rod with a solid rod? I know it's not ideal, but this engine will go in an antique car that won't see more than 1,000 miles per year, max. I was thinking of using drill rod and heat treating the ends.
Any brilliant ideas out there?
Tishabet 03-28-2009 02:01 PM
No suggestions, but... what kind of car?
VincentVega 03-28-2009 02:07 PM
Can you find a pushrod with the correct ends and diameter and weld them to length?
cgarr 03-28-2009 02:12 PM
I think SCAT (VW guys) makes a set of 4130, .312 dia. you cut to length then insert the tips. I used these for my 912. Dont remember how long they come, but you could get some tubing and make them too.
http://www.cbperformance.com/catalog.asp?ProductID=65
Porsche_monkey 03-28-2009 02:31 PM
1929 Hudson. Straight 6 engine, 289 cubic inches. It's big.
http://www.phelpsclan.com/Hudson/engine.html
Porsche_monkey 03-28-2009 02:33 PM
My engine has a lower crankcase, centre casting with pistons and exhaust valves, then a head with the intake valves. The push rods are really long, so anyhting relatively modern is much shorter.
I'll try the VW sources Monday. And post a picture when I get it assembled.
red911sc 03-28-2009 02:46 PM
Custom push rods are fairly common in the drag race world. You may also find that someone like this can make them for you very inexpensively
http://www.mantonpushrods.com/Pushrod-Info.html
Tishabet 03-28-2009 02:46 PM
Sweeeeeeet! I love Hudsons. I have a '38 Buick which has a 248 cubic inch straight eight, makes an astounding 100HP :D
Tim Hancock 03-28-2009 03:32 PM
Here ya go. http://www.aircraftspruce.com/catalog/mepages/4130tubing_un1.php
I order from them often and they sell all kinds of different size/wall thickness 4130 tubing by the foot.
DUK 03-28-2009 04:54 PM
http://www.compperformancegroupstores.com/store/merchant.mvc?Screen=PROD&Store_Code=CC&Product_Cod e=Magnum_5_16&Category_Code=PSHRD
Porsche_monkey 03-29-2009 06:14 AM
I'll follow up on those suggestions, thanks.
