Ronbo's Avatar
Bubbling Swimming Pool
My in-ground concrete swimming pool has started blowing bubbles from the water jets. I have to assume that there is a leak somewhere between where the water goes into the skimmer and reaches the pump. The filter has little to no pressure. I checked for leaks around the pump skimmer basket lid but didn't find anything.
Is it possible that the underground pipe could have a hole in it? Is there a way to check this before calling a pool repair service?
Thanks for any insight
Ron
'88 Coupe (formerly)
Old 03-28-2009, 02:03 PM
notmytarga's Avatar
Try resealing the leaf basket cover and its gasket- ahead of the pump and filter - any low pressure will pull in air. It won't leak - it will just allow air in.
Other causes could be a low water level or even foam toys in the skimmer.
Start simple - don't start digging up pipes. Yet.
75 911S Targa - Mine from 2001 until sold to Germany buyer 10/2016
<ALL DIY> Brakes/Wheels '01, Body/paint/restoration 7/04, Suspension 3/07
Engine rebuild - done 7/08 - added 28 tube cooler and SSIs - running strong. Ducktail painted.
2021 MachE, 2012 Outback, 2019 Crosstrek, 2018 Impreza wagon
Old 03-28-2009, 02:12 PM
Unregistered
sammyg2's Avatar
An easy way to check for vacuum leaks is to use shaving cream. Squirt it on joints and such, if there's a leak it will show up as a hole in the cream. Only works on accessible areas tho .........
Old 03-28-2009, 03:46 PM
Detached Member
Hugh R's Avatar
Silicone grease on the rubber 0-ring on the leaf basket, good call.
Hugh
Old 03-28-2009, 03:50 PM
Water level could be low and sucking air at the skimmer. If its low the pump could run dry.
1990 Wanderlodge PT-40
75 911S Silver Anniversary
1952 MGTD
1983 Mercedes 300 TD
1969 Lincoln
Old 03-29-2009, 08:02 AM
one of gods prototypes
bell's Avatar
this could also be caused by a clog or restriction in the feed to the pump slowing the water down.....causing the water level in the filter to be low........just like my fish tanks
Brought to you by Carl's Jr.
Old 03-29-2009, 10:00 AM
Bleed the filter?
Old 03-29-2009, 09:13 PM
Ronbo's Avatar
Thanks for all the ideas. The water level is fine and the filter is bled, so I'm going to pursue the other suggestions. Thanks again to everyone!!
Ron
Old 03-30-2009, 04:30 PM
coulda, woulda, shoulda
johnco's Avatar
Air bubbles in the strainer basket are usually caused by some small leak that can be anywhere from the skimmer/main drain to the pump itself. rather than start digging up lines and breaking concrete chasing a pinole you may never find, hire a leak detection company to locate and mark the leak for you. Down here they charge about $450 to check everything. Maybe a little more if you have spa jets, waterfalls, etc.. you might want to repair it yourself once they located it because I'm told they charge $1200 to cut out concrete and repair. I usually charge $450 a leak, so I've done many. suction leaks are harder to find than pressure side leaks. unless you get lucky enough to get close enough to hear the sucking noise... you'll be digging up every foot of pipe. we go weeks with no rain, then weeks of rain which makes the ground shrink and swell. that's when the fittings start to crack.
John
74 911s
Old 03-30-2009, 05:23 PM
Student of the obvious
LeeH's Avatar
Mine has a printed warning against this... why would that be? I know mine tends to leak here, but never understood why the lube would be a problem.
Lee
Old 03-30-2009, 10:38 PM
