This problem is impossible.
The area of an equilateral triangle is increasing at the rate of 4 in²/min. At what rate is one side increasing when the area is 16in²?
Been working on it for like 5 hours now. Can't figure it out. About to throw someone through a wall. |
I assume you're in Calc and working with derivatives and related rates?
< EDIT >BLAH, BLAH, BLAH. THERE WAS A TYPO IN MY FIRST ANSWER. GIMME A MINUTE TO REWRITE IT.< /EDIT > A great online resource for math, especially college (Algebra, Calc I/II/III and DE) is "Paul's online math notes" (apparently a professor at Lamar Univ in Texas) Here's a link to his Calc I notes. http://tutorial.math.lamar.edu/Classes/CalcI/CalcI.aspx Here's his main site. http://tutorial.math.lamar.edu/ |
< edit > I screwed up again, thanks dad911 < /edit >
This is more difficult, but it still works out the same way. Getting the measure of a side when the area is 16 is messier with the correct formula (assuming you can't use a calculator and give the answer in decimals). 16 = √3/4•s² s = 8/fourth root of 3 s' = looking for A = 16 A' = 4 A = √3/4•s² A' = √3/2•ss' s' = 2A'/(s•√3) s' = 8/(8/(fourth root of 3)•√3) Assuming I didn't screw up again.... s' = 1/fourth root of 3 Sheesh, I hope that's right, but having to use the fourth root would be unusual for most math classes |
Nerd. :)
what masraum said
steve |
This is home http://forums.pelicanparts.com/uploa...1240269257.jpg If I can't get the company to spring for a couple of better monitors (1280x1024 left and 1440x900 right) I'm going to have to buy my own. Notice the titanium 911 con rod, G50.50 pinion (From Hank Watt's Green Monster), and 2.7L P&C (pen holder). I need a Mg intake valve cover and standard steel rod. I also want to bring in my old fan and shroud. You can never be surrounded by enough greasy old car parts. |
area is represented as: http://forums.pelicanparts.com/uploa...1240269702.gif http://www.mathwords.com/a/area_equilateral_triangle.htm |
how do you type that square root symbol?
Hahahah, damn! |
A few beers less, and I would try to figure out the answer, maybe tomorrow.... but then again, a few beers more, and I would have agreed with masraum(steve) |
Hmm that Area equation is probably where I was going wrong too.... WHY WAS GEOMETRY 17 YEARS AGO?! |
This forum/thread may shed some light:
http://www.physicsforums.com/showthread.php?t=297625 |
Dude that was your 911th post. :)
Ok, Use Heron's formula, (not Pythagorean) to get the area, and you will get the same area formula that I showed above. http://en.wikipedia.org/wiki/Heron%27s_formula
2. area (per se) = 16 3. all sides equal ====> only need to know about any one side you need the formula to derive the area from the length of a side then rearrange to focus on side length differentiate if non-linear, evaluate the rate at #2 above & you are done go for a walk when frustrated good luck and you can tell your prof. that I did NOT give you the answer. |
I KNOW the process. I can't do the math or put the picture together.
Well, after doing it multiple times (obviously making stupid errors along the way), I think I got it.
A = (s²√3)/4 s= 8/(3^¼) A'=(√3/4)(2s)(s') 4=(√3/4)(2)[8/(3^¼)](s') 2=(√3/4)(8/(3^¼)](s') (8/√3)=[8/(3^¼)](s') (8/(3^¼)) / (8√3) = s' s' = 3^¼ / 3^ ½ = 3^(-¼) s' comes out to be 1/(3^¼). |
| All times are GMT -8. The time now is 12:48 AM. |
