Junk it... (save time and money and buy the same 4runner if you want but newer)
Well, God is smiling on me. this took a little under an hour. Came apart easier than I could have imagined. new parts (fenders, bumper) so I'm looking forward to it being back on the road next weekend.
http://forums.pelicanparts.com/uploa...1243184801.jpg http://forums.pelicanparts.com/uploa...1243184825.jpg http://forums.pelicanparts.com/uploa...1243184843.jpg http://forums.pelicanparts.com/uploa...1243184866.jpg http://forums.pelicanparts.com/uploa...1243184881.jpg http://forums.pelicanparts.com/uploa...1243184899.jpg |
I would have said dump it and get a Land Cruiser, but I'd wheel that sob in its current condition.
i see you have backup transportation.
Matt, 40s are too small (had one, loved it) and 80s are too big. For my needs, the 4Runner is perfect, though could use some more power. I would consider swapping in an old Mustang 5.0 if it were easier (already cheap), but it's really not a smart move.
Ny: yes, the bike makes me smile every time I put a helmet on. Hope to take it to the track at least one day this summer. |
Tiny bit of progress. I decided to bond the quarter on versus weld. the sheetmetal is like heavy tin foil and much easier to get on with some structural polyurethane and lots of clamps. Quick test fit here. The issue really is time. hoping to have the whole thing done next weekend. Front end should be here on Wednesday.
http://forums.pelicanparts.com/uploa...1243780577.jpg |
There are ZERO around here. None. They all have rust. |
oh, they have rust in utah. my good friend has one, rust and all.
Two big boxes arrived today. 30 seconds and 2 bolts later...perfect fit. Not bad for a $60 fender.
http://forums.pelicanparts.com/uploa...1244060119.jpg I hope to spend a good hour tomorrow and get the front end all put together with the new bumper, should have ordered a new valence. This has the potential to be a nice truck. |
Front end is sort of done. Waiting for special connectors for the bumper corners from Toyota so I can place the bumper better. Then going to order a new valence and it's done. Hoping to pick up a parts truck on Saturday for the gas tank, rear light, rocker sheetmetal and some odds and ends I need.
http://forums.pelicanparts.com/uploa...1244137525.jpg |
For a nice power boost, look at swaping in a 7MGTE engine. That'll give you some nice get-up and go on the road. If you want non-turbo, the 7MGE is another option. Still better than what you have, even if it's the v6 (POS)
turning out much better than I would have guessed. So you're paying yourself what? about 10 cents an hour?
Oh, I forgot to finish with 'yo', or is it 'werd'? |
kaisen - you're apprently an idiot when it comes to engine swaps on Toyotas. You can pick up a low mile import engine and harness for around $500. There are a million and one "how to" posts for doing the swaps on the off-road boards. If you have a clue as to what you're doing it can be done in a weekend.
I only mentioned it because there was talk of swapping in a Mustang engine. That'll cost you more than double the 7MGTE swap. Oh and by the way, I'm 37, so stick the "werd" up your a$$ |
It won't happen for a long time, but do you have any links to installs on the 7MGTE. I love this truck and someday it will be nice. Might shoot it with an industrial gloss black enamel in August--quick and easy. It would be great if it could also go up hills and get out of its own way, though it has towed many 911 parts cars with ease, but having a real motor in it would make it complete. |
I have a gallon of Guards Red just waiting for a home. That and some fuchs :D
Hmmm! I could definitely see that. Keep that paint safe. I'm hopping mad right now. I drove 2.5 hours yesterday to see a parts truck, it was perfect for me: gas tank, rear light, rear doors, and lots of other good parts. I made and offer for $300, they accepted it earlier today, I said I'll be out on Saturday with a trailer. When I was there, she mentions some other guy who was interested and she had just found his phone number. I got an email minutes ago that the guy came by today and bought it for $400. WTF? god damn fat white trash. |
I'm not sure you can find a good complete Supra 7MGTE for $500, but I'd believe $1000 Are you forgetting all the small swap parts? You'll easily have $4000 when everything is done (which is about twice the 4Runner's value, like I said) Then you'll have a nose-heavy 4Runner Don't believe the $4000 figure? Here's a guy who's done a few and this is with ZERO labor: http://www.supracharged.com/4runner/swap/7m_partslist.html Parts needed auto JDM engine 890 used ecu 75 harness 80 igniter 50 injector resistor 30 hvac sensor 30 afm 75 used motor mounts 30 used bellhousing 50 steel fuel line 10 timing belt 20 aluminum radiator 220 heater hoses 30 upper/lower radiator hoses 60 12" dual electric fans 230 3" exhaust w/muffler,cat 400 used a/c compressor 100 ac lines 100 power steering lines 35 used motor mounts 30 IC piping w/mandrel bends 100 silicon hose 80 Air filter 35 misc parts and supplies* 500 walboro fuel pump 110 Intercooler 300 labor 0 0 total $3670 * misc parts and supplies This includes stuff like electical wire, battery reloction, steel, welding supplies, extra hoses and clamps, oil, filters, shop supplies, and many other small things that just keep adding up. Be prepared to spend $300-$500 depending on what you buy. " Oh, and Eminem is 37..... did I bring up age? Werd |
you boys wanna take it outside.
| All times are GMT -8. The time now is 10:15 PM. |
