-   -   Ice maker install question (http://forums.pelicanparts.com/off-topic-discussions/480306-ice-maker-install-question.html)
Joe Ricard 06-16-2009 04:07 AM
Wife buys a fridge without ice maker installed. Sales guy says "oh we have a kit with a rebate, Pretty easy to intall".
Yup Should be easy, heck I rebuild Porsche motors!
everything hooked up water turned on under sink, nothing out at the ice maker. Hmm flip lever up and down no water. re-check my work wires hooked up water pressure sitting at top of solenoid but not going through.
More head scratching, get meter test power at solenoid 22VAC flip lever up power goes away. read continuity of sloenoid coil it's good. Just not picking up, no hint of click or nothing.
what sort of votage should go to this? 22 VAC or 115VAC ?
No wiring diagrams anywhere,
stomachmonkey 06-16-2009 06:16 AM
Lever up = off on an ice maker.
They are fairly simple, they kinda either work or they don't.
Check the unit for packing materials that you may have missed. Happened to me once when putting one in.
gr8fl4porsche 06-16-2009 08:13 AM
Ice makers are strange when you install them. Nothing happens at first.
Hook up the wire and water. Leave lever down.
Go to bed.
In the morning there will be ice.
Throw away the first couple of bins full to make sure you are not drinking little pieces of the manufacturing process.
dhoward 06-16-2009 08:22 AM
+1
OR....take off the faceplate. There should be a circuit board under the cover. Find 2 little holes with 'test' written on them. Make a jumper out of 12 guage copper wire. Insert the wire into the holes. This bypasses the temperature logic and causes the icemaker to run through a cycle.
legion 06-16-2009 08:24 AM
Phase 1: Connect Icemaker
Phase 2: ?
Phase 3: Ice!
Joe Ricard 06-16-2009 08:40 AM
Go to bed.
No joke? I was getting pissed because somethig so simple was whipping my tail.
Hmm, Circuit board, temp sensors, Freaking eh.......
Thanks ya'll.
Zeke 06-16-2009 08:56 AM
Yeah, I think there's a timer thing. On the last kitchen job I was on, the stupid cabinet guy installed the fridge along with the plumber. They left the packing tape on the wire that gauges the amount of ice in the tray. I get there the next day to hear all this groaning coming from inside the freezer.
Working with today's tradesmen is such a joy.
+1 on trowing out the first couple batches.
gr8fl4porsche 06-16-2009 10:22 AM
Forgot to add that I install a water purifier in the middle of the water line to help the ice taste better. I put them in a convenient location, such as up in the floor joists below the fridge so they can be changed regularly. GE makes a $10 filter that works fairly well if the fridge doesn't have a built in one.
Hugh R 06-16-2009 10:25 AM
If its a fridge with a bottom pull out freezer drawer like mine. The light switch is an interlock so it doesn't dump ice when the drawer is pulled out.
Joe Ricard 06-17-2009 03:49 AM
And we got ICE !!!
I am so glad that is done. OK back to building my race car.
red-beard 06-17-2009 04:12 AM
Phase 2: ?
Phase 3: Ice!
"Hey! What's phase 2?"
"Well, Phase 3 is ice."
Joe Ricard 06-17-2009 07:06 AM
Phase 2 is Wait.
Directions didn't say wait till it's good and damn ready to make ice.
rammstein 06-17-2009 07:49 AM
Icemakers wait until you are sleeping I think. That's when the ice gnomes come out.
legion 06-17-2009 08:50 AM
Gah! Not the ice gnomes!
LeeH 06-17-2009 09:28 AM
This cracked me up! I've only rebuilt one engine, but after that it seems like you should be able to fix anything AND is should be easy.
Pazuzu 06-17-2009 09:29 AM
Originally Posted by rammstein (Post 4727148)
Icemakers wait until you are just barely falling asleep, enough that your all tired and dreamy and comfortable but not asleep enough that you don't get violently awoken from the sound of something banging around in your kitchen I think.
Fixed that :)
LakeCleElum 06-17-2009 09:56 AM
Somedays, I can outdrink my icemaker!!!!!!!
gr8fl4porsche 06-17-2009 11:05 AM
I call those days 'Saturdays' :)
