abit off center
Remote for a winch?
I have a HF 110 volt winch in my hangar to pull the plane back inside but it has a hand held hard wired control. I want a wireless, like garage door opener controller to operate it. HF sells a 12V winch with a car type remote that works nice or our car hauler, I want this type of remote on my 110V winch, any add on things out there like this??
______________________ Craig G2Performance Twinplug, head work, case savers, rockers arms, etc. |
Used to be Singpilot...
Location: Sioux Falls, SD is what the reg says on the bus.
I know they sell IR remotes for appliances / TV, that kind of stuff. So long as the amps were in spec, or you rig a relay setup, that would do the job.
So it's tough steering and wing walking while holding the wired remote, huh? |
abit off center
I need a remote that will work forward and reverse, its mainly for when I feed out the cable, I could make the hard wired control longer but I hate wires all over..
Platinum Member
Slumlord
This is a typical 'crane' application. But I expect they would be redundant controls for safety, and not economical.
http://www.remtron.com/crane.asp
84 Cab - sold! 89 Cab - not quite done 90C4 - winter beater |
MAGA
That airplane is not THAT heavy Craig.... Man up and drag it in like god intended when he invented tail-draggers.
Of course this is coming from a guy who has fell on his arse more than once on an ice patch while pulling a measely 300 lb homebuilt. ![]()
German autos: '79 911 SC, '87 951, '03 330i, '08 Cayenne, '13 Cayenne 0% Liberal Men do not quit playing because they get old.... They get old because they quit playing. |
