Dynolicious question
How important is it to get the weight of the car perfect in the setup of the program? I assume if you put it in to light it would record less HP? and if you leave the 15% drive train loss at zero that should pretty much give you the engine HP then?
Wife just got the new 3G and I have to play! |
The car weight (including passenger) is needed to calculate wheel HP, because this is based on acceleration. The number you get if you set drivetrain loss to zero is wheel hp. The 15% drivetrain loss is needed to get the engine hp.
| All times are GMT -8. The time now is 08:08 AM. |
