Mullion Windows, but not...
I've always heard the windows that are leaded glass in a diamond pattern called "mullioned windows".
like this http://www.romneymin.com/complete_stone_window.jpg These are real mullion windows. According to my reading, mullions are vertical structural supports in windows. http://www.justinbrownjoinery.com/US...S/100_1125.JPG http://www.mejeyes-stonemasons.co.uk...ics/rest05.jpg So what are the windows above called. If you were going to do a search for them online, what would you search for? I found some stuff that said that they were muntins, but when I search for muntins, I find the common checkerboard pattern that's usually 6 or 9 panes like these http://www.vinylreplacementwindows.o...ntin_grids.jpg http://www.bermudaglass.bm/6muntin.jpg so what the heck are the diamond patterned windows? Would they just be "leaded glass windows"? Is there a specific name for them. I'm not in the market. It's just one of those things, I don't know, and it's killing me. |
Muntins are another name for grills or grids.
In new construction, Mullion windows are when two windows are attached together, side by side. For example, If I order (2) anderson 3052 windows mulled, they are attached together before delivery, and come as 1 unit. |
Steve, the leaded windows on top are called divided light leaded windows. What that means is that each section of glass is truly a separate piece of glass that is held together by the lead - all of the lights are divided by the lead. You can buy windows like that, but they cost a fortune and are practically hand made.
What is more common today is lead windows with "simulated divided lights". What this means is that the glass in the window is all one sheet of glass with lead imbedded on the top and bottom to simulate the appearance of truly separate "lights" or pieces of glass. The performance of simulated divided light windows is actually better, because there are fewer joints and they're machine made. Good architectural quality simulated divided lights will look like real old fashioned hand made leaded divided lights. Muntins are the removable wood things you stick inside a larger window that make it look like you have divided lights. Mulls or mullions are the joint between two windows that are joined in the same rough opening. The top windows actually aren't mulled because they have their own rough opening. There is framining around the windows, so even though they're right next to each other, they aren't mulled. The lower white vinyl window you posted also aren't mulled. It looks like that is a sliding window that is one single unit. In other words, the window is built that way at the factor with the frame and two sash, rather than being separate windows, each with their own frame and sash that were joined by a dealer or installer. But from an appearance perspective, that is what a mulled window would look like. I would look up the web sites of Andersen and Marvin windows and see if their architectural series include lead simulated divided light windows. I'm sure Marvin does. Andersen might. Then just do an internet search on leaded windows. |
thx for the info. It's funny. Back in the day the windows made of separate small pieces of glass were made because they were cheaper (large panes were hard/expensive to make) and now the smaller ones are cheaper because putting a bunch of small panes together is more difficult. How times change.
| All times are GMT -8. The time now is 02:00 AM. |
