-   -   MAC guys...a burning question (http://forums.pelicanparts.com/off-topic-discussions/489875-mac-guys-burning-question.html)
targa911S 08-05-2009 02:12 PM
Ok so I have had no troubles with burning CD's from itunes on my internal CDR burner. Now lately I select "Burn disc" - insert a blank CD, and it kicks it back out and I get this message
" the attempt to burn a disc has failed. The device failed to calibrate the laser power for this media."
Now it has happened with ALL types of blanks, Sony, Imation and maxell, and very suddenly.
I don't get it. Anybody have to deal with this before?
PS: I can burn to my external DVD-R, no probs.
stomachmonkey 08-05-2009 02:39 PM
Drive is probably going/gone.
Happens.
What box? How old?
targa911S 08-05-2009 02:50 PM
it's mini, about 5 years old.
Pazuzu 08-05-2009 02:55 PM
Take a blank CD-R, and smear blueberry jelly on both sides, then put it in the drive. you need to refresh the "blueness" of the laser in there.
BlueSkyJaunte 08-05-2009 03:01 PM
Dead drive.
I had one (in a PC) go that, when burning, made CD-Rs look like caffeine crystals under magnification. It was both beautiful and frustrating as hell.
targa911S 08-05-2009 03:11 PM
Damn! At least I can still burn on the external DVR. Man it will be hell replacing it in that little tiny box. Damn!
Pazuzu 08-05-2009 03:13 PM
Can you even get replacement drives for the Minis? I haven't played with one, I wasn't sure if it was a standard bay inside, or some specialty item.
stomachmonkey 08-05-2009 03:16 PM
New superdrive from OWC is ~$80-90.
Bout a half hour for a first timer from start to finish.
targa911S 08-05-2009 03:18 PM
I think it's a lap top drive.
What is OWC?
targa911S 08-05-2009 03:21 PM
Never mind I googled it. Thanks for the help guys.
stomachmonkey 08-05-2009 05:31 PM
Sorry, shoulda linked.
The current Superdrives do dual layer discs. Don't recall but pretty sure your current drive does not so may be worth your while.
gr8fl4porsche 08-05-2009 05:38 PM
I have a stack of dead burners. If you burn a lot, they only last a couple of years at best.
targa911S 08-05-2009 06:40 PM
That place is great! I did a "Chat" tech Q&A. Great stuff.
jyl 08-05-2009 07:40 PM
I'm replacing the optical drive on my iMac. Cost $90 for a new one. You can do it too.
targa911S 08-05-2009 08:00 PM
Ok then. I'm pretty fearless about these things.
jyl 08-05-2009 09:10 PM
Alright, done. Took about 40 min. Probably would have helped to have consulted some directions first. I simply removed the iMac back and started looking for screws to remove around the ODD. I bought a naked drive (from OWC, as it turns out) so had to transfer over the perforated shield/bracket thingy, that took a little while for me to understand. Your Mac mini might be harder, but I bet you do it faster, because you'll actually have instructions in hand. I needed a small Phillips and a small Torx driver (bought a set for $10 once, they have been very useful). And a pair of chopsticks to retrieve the screw I dropped.
New drive is ripping CDs as we speak. How come with a Windows PC I'd still be installing drivers now, whereas with the Mac you simply install the hardware and the Mac starts using it right away?
This iMac has been going since 2004/5. It is a G5 that gets used 6+ hours a day by the whole family. I've maxed the DRAM, replaced the hard drive, added a wireless card, now replaced the ODD. Its been quite the trooper of a machine. It's time is coming, alas, because the G5 is just too slow (takes me literally all night to rip a DVD) and because Leopard won't install on a G5. So it will be retired to the family room as a music player, I guess. Macs are good stuff.
gr8fl4porsche 08-06-2009 07:06 AM
Optical drives do not need additional drivers in windows. How would you be able to load a disk with drivers without the drive? (yes I realize there are many options these days such as the internet, flash drives, etc. but you get the point).
emcon5 08-06-2009 04:14 PM
I thought for sure this was going to be like the hardest part of rollerblading.
:p
Tom
jyl 08-06-2009 04:38 PM
I guess the generic drivers in Windows should work with most CD/DVD drives then.
