Valenntine & Escort question
Does anyone know if the connectors for the escorts and valentine radar detectors are the same?
Reason, my truck is hardwired for an Escort, I have the Valentine in my WRX also hardwired. Can't find the Valentine cigarette jack cable.. If I connect the Valentine to the Escort wiring... will I let the smoke out? Both are phone jack type connectors. |
I'm pretty sure that the V1 is a straight through phone cable. So maybe you can find some info on the Escort and compare.
I'd be cautious, even if the cables use the same pin-out, the pins may have different functions. |
test the outputs of both with your multitester...if the fitting fit and the readings match..bingo.
Its easier to ask here :p
all escorts have exactly the same connectors, 1 intake, 1 female, 1 exhaust
they only differ in price, function, and possibilities depending on the price, the function may change, as will the possibilities |
you trying to say something?
speak up |
As soon as I clicked "post" I knew the title of this thread would open ups some interesting remarks :cool:
You don't give the model of the Escort, so this was the first diagram I found.
http://pinouts.ru/CarElectronics/escort_detector_pinout.shtml I give up on the V1 search. I found a diagram for that a while back. Search for old posts with Rick Lee and the V1. |
I think it was an Escort 7500... someone decided they wanted it more than me so they broke the window and took it :rolleyes:
I'm going to break out the multi meter and check the pin outs |
Newsflash!!
The pin outs for the Valentine and Escort radars detectors are DIFFERENT need to rewire my truck now |
| All times are GMT -8. The time now is 10:53 AM. |
