It is a fleet truck and we use it heavily, it gets 23MPG like clockwork. I love my Tacoma and FJ, both have high miles for their age (60K on the 2007 FJ) and neither give me a single problem. Good luck with your Taco your good to go now for another 200K miles. |
Nice pics. If that were my truck I'd replace or repaint or powder coat a few of the rusty things that they didn't replace (shocks, exhaust, etc) just to get that all-new truck look. You are so close already.
I don't remember what it's called, but I've got some of it. :D |
I'm pretty sure this is what I have (probably got it at Autozone or Advance Auto)...
http://forums.pelicanparts.com/uploa...1254428635.jpg The way I remember the directions, it tells you to hit the rusty areas with a wire brush briefly to knock off the high spots, then blow or wipe off the area to remove the excess, then spray on. It goes on clear and starts to turn the rust black fairly quickly. Wait a certain amount of time (24 hrs., I think) then paint. Or not. It is available in a bottle so you can brush it on, too. http://www.amazon.com/gp/product/B0015DMJZA/ref=pd_lpo_k2_dp_sr_1?pf_rd_p=486539851&pf_rd_s=lp o-top-stripe-1&pf_rd_t=201&pf_rd_i=B001QGKFPM&pf_rd_m=ATVPDKIKX 0DER&pf_rd_r=0H4BHH5873X8NA69SVW4 Depending on how much you need to do, that might be better... otherwise you might get high under there with all the overspray and fumes. :eek: |
That's basically like gun bluing in a can i think. It does work, my cousin has used it in the past.
There's MANY American cars that have systemic issues that aren't ever admitted to or repaired by the makers. Toyota really stepped up by replacing entire trucks in some cases, or fixing the problem. I'd love to get all new bushings, mounts, etc for free. My '91 Land Cruiser has 193k. Records since new. The two most expensive repairs were a fuel pump at 150k and a water pump yesterday. |
I bought a new Toyota 4x4 SR5 in 1985 and within about 6 months the chrome was peeling off the rear bumper...and that was in Southern California. They replaced the whole rear bumper with no issue.
I think they are great trucks and thought they would of had the whole rust issue fixed by now. I have 5 American full size trucks with no issues of frame rust. |
so how much snow and winter salt are in Kentucky these days?
We had a similar experience with Toyota recently with the TRD exhausts we make, the tip was specified as a certain material, it turned out that the material we used was below par and it "browned " with heat....not something a polkished stainless tip should do. end result? we recalled and replaced the effected systems (at GREAT expense) and had to cover the actual wararnty costs for replacement systems to be installed on the kits in the field.... |
there is NO BETTER SMALL TRUCK ON THE PLANET. none that even compare. none. ditto earlier style Tundras (just change 'small' to 'not quite full size'). |
I just turned 50K on my '06 Taco and while there is some rust on the frame it is not an issue in any way.
Long term, I would trust a Toyota truck any day over anything from the big three. That said, if I needed a FULL SIZE truck for work every day to beat the hell out of in contruction type work, I would probably buy a Chevy or Ford and just fix anything that breaks. I can't imagine getting in a high dollar new Toyota Tundra with greasy or muddy clothes and throwing busted up concrete into the bed. Chevy and Ford build a pretty decent full size truck but IMO, Toyota has them beat in the smaller trucks when it comes to minimal maintenance required and long term reliability.
George |
I would be in the market for a newer Toyota Tacoma, if it had not become a full size truck that's not available with 4cyl in a 4x4. The way they went, I might as well keep driving my old beater full size. No gas savings there ...
George |
| All times are GMT -8. The time now is 10:53 PM. |
