LOL, i was thinking the same thing. Too bad our guys didn't have circa 1917 water-cooled browning machineguns.
http://www.militaryfactory.com/small...ng-m1917_5.jpg |
Something has been bugging me about this, and I just figured out what it was.
In a 3 gun match a few years ago, I put 147 rounds through an AR carbine in 2 minutes (timed stage, 3 rounds left in my 5th magazine when the timer went off). Yeah it got hot (it melted my nylon web sling), but it still ran fine. |
I think it's a safe bet that the actual time frame the ammo was fired in was much shorter than the soldier recollected, or was reported.
A well maintained AR will run 500-600rds continuous no problem, but it becomes prone to cook-offs if you leave a round in the chamber after firing all those rounds. If you reach the point of cookoffs you just lock the bolt back, squirt CLP directly into the chamber until it drips out the other end of the barrel, and douse the exterior of the barrel in canteen water, then you're probably ready to roll again for another couple hundred rounds or so. M60s and other machine guns are very prone to overheating and can develop "run away gun" syndrome. I saw that on a range at Fort Sill once, it was nuts. The thing just keeps firing until you twist the belt and jam it. As AR's heat first the handguard becomes to hot to hold, and you grab the magwell. Once the magwell gets too hot you grab the Magazine. Once those are getting uncomfortably hot it's time to cool that bad boy down because you're in serious cook-off territory. |
LOL. Dude, you funny.
Reading the ar15.com thread linked above, there is some good information in there, before the train goes off the tracks completely around page 4. The leaked "rough draft of the historical analysis of the Battle of Wanat, July 13, 2008" is linked, and can be read here:
* Battle of Wanat Historical Analysis: Rough Draft Release*by*A Battlefield Tourist This is the report the AP reporter used for his hit piece, which shows he was a little hard and loose with facts. The report mentions the M249 barrel getting "white hot", not the M4s, and at least one of the M4 failures (Ayers, RIP) was because it took a bullet through the lower receiver. Quote:
http://www.defensereview.com/m4m4a1-carbine-reliability-issues-why-they-occur-and-why-theyre-our-fault/ |
That's a seriously detailed report, thanks for posting it.
It really seems as if this one battle was what i suggested some months back in PARF should be our strategy for A-stan, but on a much smaller scale than i envisioned. Sure sounds as if it was one hell of a fight, even closing to hand to hand ranges at times. I actually walk away from that report thinking those guys were lucky to have thier M-4s and not M-16A1's. |
Submitted without comment:
TheFiringLine Forums - View Single Post - M4 Failure makes headlines Quote:
So if I read that correctly, if you maintain this weapon, it is practically foolproof; we have failed to adequately define PMS/maintenance hence failures
How long could you shoot the bad to the bone MG '42 the Germans had before it would overheat? I know they had a pretty impressive rate of fire, but you burn that much energy you create a lot of heat, gotta go somewhere. |
Fast forward to about 1:55, you can see how it comes out: YouTube - German Machine Gun MG42 |
IAR |
The problem with open bolt weapons as battlefield systems is that in harsh environments they are prone to eat a lot of dust, dirt and debris.
The US military could certainly put full length fluted and thermally coated barrels on pretty much everything, but it would cost a lot of money. I'm personally not really worried about it, even if i fire off every round from every magazine i own including my Beta C double drum it's still only 600rds. |
More on M855 armor penetration capabilities:
"Q. Isn't 7.62 NATO much better for long range penetration than 5.56 anyhow? Why would I want to use 5.56 when I could send 7.62 downrange instead? Well, yes and no. For some penetration mediums like mild steel, M855 is actually superior. Consider a recent research report: The SS-109 can penetrate the 3.45mm standard NATO steel plate to 640 meters, while the 7.62mm ball can only penetrate it to 620 meters. The U. S. steel helmet penetration results are even more impressive as the SS-109 can penetrate it up to 1,300 meters, while the 7.62mm ball cannot penetrate it beyond 800 meters. The current production 7.62×51mm NATO ball cartridge has remained unchanged since its adoption by NATO in 1953. As typified by the U. S. M80 ball and the Belgian M77 ball, this cartridge propels a 147-grain cupronickel-jacketed lead bullet at a muzzle velocity of 2,800 fps (848 mps). Total cartridge length and weight are 2.80 inches and 386 grains, respectively. Utilizing a standard 22-inch barrel with a rifling twist of one turn in twelve inches (M14 rifle), the maximum effective range of the 7.62×51mm ball cartridge is listed as 620 meters (682 yards). The U. S. M80 and the Belgian M77 ball projectiles can penetrate the standard NATO 3.45 mm (.14 inch) thick steel plate up to a range of 620 meters and can penetrate one side of the U. S. steel helmet up to a range of 800 meters (880 yards). In barrier and fortification penetration tests, the 147 grain ball projectile can consistently penetrate two test building blocks. The new SS-109 cartridge propels a heavier 62-grain semi-armor piercing projectile at an initial velocity of 3,050 fps (924 mps). The improved projectile contains a 10-grain .182 caliber hardened steel penetrator that ensures penetration at longer ranges. The new projectile can penetrate the standard NATO 3.45mm steel plate up to a range of 640 meters (704 yards) and one side of the U. S. steel helmet up to a range of 1,300 meters (1430 yards). In tests of barrier and fortification penetration however, the steel penetrator of the SS-109 could not pierce any of the test building blocks. The primary advantages of the intermediate power 5.56×45mm NATO cartridge are summarized as follows: (1) the penetration and power of the SS-109 version are superior to the 7.62mm NATO and more than adequate for the 300-meter average combat range documented in actual battle (ORO studies): (2) the lower recoil generated by the 5.56mm cartridge allows more control during full automatic fire and therefore provides greater firepower to the individual soldier; (3) the lesser weight of the 5.56mm ammunition allows the individual soldier to carry more ammunition and other equipment; (4) the smaller size of the 5.56mm ammunition allows the use of smaller, lighter and more compact rifles and squad automatic weapons and; (5) the lethality of the 5.56mm projectile is greater than the 7.62mm projectile at normal combat ranges, due to the tendency of the lighter projectile to tumble or shatter on impact. 5.56-mm NATO ammunition weighs only 47% as much as 7.62 mm NATO ammunition. In summary, the 5.56mm NATO provides greater firepower and effectiveness than the larger and heavier 7.62mm NATO." The AR15.com Ammo Oracle Here's a link to the pelican thread on 5.56mm ammo selection: http://forums.pelicanparts.com/off-topic-discussions/496791-what-your-choice-5-56mm-ammo.html I also found this on the ammo oracle link: "M193 and M855 at anything greater than 2200 fps will generally defeat all body armor up to and including Type IIIA. How much damage those rounds will do AFTER penetration is guesswork. In shorter barrels (14.5" and below) that damage is likely to be limited and wound profiles in such instances will resemble .22LR hits. With higher velocities it's still hard to imagine explosive fragmentation at anything but point blank range but M193 and M855 will certainly defeat all soft armor." It seems to me the newer heavier 77gr US Military bullets would still retain sufficient velocity to fragment (2100fps floor) even after penetrating class IIIA armor. |
I just fired 204rds of full power .223/5.56mm through my AR Carbine in about 3 to 4 minutes yesterday, trying to see if i could get the rifle to malfunction.
The first part of the test was a standard silhouette target at 25 yards. The second target was a standard silhouette at 7yards. I started with with aimed fire, shooting 13rds of heavywieght max. pressure Double Tap 77gr JHPBT's to get the barrel warm and fine tune my zero. I then reloaded the weapon and went into "mad minute mode", firing a 100rd beta C double drum mag of American Eagle 50gr Federal JHP as fast as i could while keeping the front sight post centered on the target. I quickly followed that up with 3x 30rd mags of the same Federal JHP ammo rapid fired and reloaded as fast as possible, again while recentering my front sight on the target between shots- one mag right after the other. No failures of any kind occured. The standard US combat loadout of 5.56mm is 210rds of M855 in 7x30rd mags. My test yesterday closely approxomated what would happen if a US soldier had to rapid fire his entire combat loadout in a matter of just a few minutes. After firing the 204rds the weapon was pouring smoke from the action, muzzle and free floated handguard tube end, but the Hogue overmolded rubber portion of the handguard was only slightly warm. Temperature inside the range was about 60 degrees F. I should have video of the Beta-C mag portion of the test in a day or two, once my buddy uploads it. |
| All times are GMT -8. The time now is 06:35 PM. |
