Go Back   Pelican Parts Technical BBS > 5 - Miscellaneous > Off Topic Discussions
Insert Tag Line HERE.....
rattlsnak's Avatar
honda samll engine question.. (pressure washer)
OK, neighbor gave me a nice Honda 5.5hp pressure washer after he bought a new one. This one has sat for a few years and was not running. After draining fuel, taking apart carb, cleaning, new plug, etc. It will crank up and run instantly at all throttle speeds unless I have the hose hooked up. If any kind of load is applied it will stall and then i noticed it will only run with thte choke blade almost closed. As soon as you try to move it to the wide open postition, no matter the engine speed, it will spit and pop and backfire and stall.
I was thinking carb issuse, but it is clean and i ran small wire through all the jets, etc, i know they are clean. So then Im thinking ignition problem for the backfiring, but that wouldnt make the lean condition.
Anyone?
Old 10-24-2009, 06:23 PM
  Pelican Parts Technical Article Directory    Reply With Quote #1 (permalink)
Used to be Singpilot...
Location: Sioux Falls, SD is what the reg says on the bus.
I have exactly the same washer, and cannot think of what may be going on. Did PO say it ran OK prior?
Old 10-24-2009, 07:38 PM
  Pelican Parts Technical Article Directory    Reply With Quote #2 (permalink)
The beauty of small engines.
Spark - fuel- air.
If it starts with a new plug it's not spark. Take off the air filter to eliminate air
What's left?
Fuel.
Make sure the fuel filter in the tank is clear. Common problem. Make sure gas flows from the line.
Take apart carb again and blow air through every little hole you can find.
Old 10-24-2009, 07:58 PM
  Pelican Parts Technical Article Directory    Reply With Quote #3 (permalink)
rattlsnak's Avatar
yes, he said he had some running issues before not much different than im having now. Yes, I took the tank off and the carb, and soaked it in cleaner, then used compressed air to blow it all out. I can see through all the jets. just doesnt make sense why it wont run without the choke closed. Its like it has a vacuum leak. i was thinking maybe the ignition/magneto unit was malfunctioning because when it backfires its more like a crisp pop, not like a fuel misfire..
Old 10-24-2009, 10:33 PM
  Pelican Parts Technical Article Directory    Reply With Quote #4 (permalink)
Double Trouble
targa911S's Avatar
crap in the tank?
Old 10-25-2009, 06:01 AM
  Pelican Parts Technical Article Directory    Reply With Quote #5 (permalink)
rattlsnak's Avatar
i cleaned it all, see above.
im just gonna order a new carb for it. surprisingly its only $28.00!! we will see what happens..
Old 10-25-2009, 08:56 AM
  Pelican Parts Technical Article Directory    Reply With Quote #6 (permalink)
Now Available for Ordering:   101 Projects For Your BMW 3 Series 1982-2000  [more info]
Buy a new carburetor. The hondas are weird. I have rebuilt their carbs to no avail. Then I replace them and they work perfectly. Odd breed but run and start better than anything.
Run marvels mystery oil in the gas and you won't be replacing any more carbs on your small engines either. The marvels will keep the new E-10 gas from ruining your carb and keep top end lubed.
Old 10-25-2009, 09:40 AM
  Pelican Parts Technical Article Directory    Reply With Quote #7 (permalink)
LakeCleElum's Avatar
I have the same pressure washer. As I don't use it often, I shut the fuel off and let it run till it quits. This keeps the carb in good shape. When turning the fuel back on, it mixes as it flows in and starts on the 1st pull....
Bob S.
73.5 911T
1962 XKE Roadster (sold)
19 motorcycles
Old 10-25-2009, 09:48 AM
  Pelican Parts Technical Article Directory    Reply With Quote #8 (permalink)
crustychief's Avatar
Try checking the governor linkage.
A nose heavy airplane flies poorly, a tail heavy plane flies once.
Old 10-25-2009, 10:11 AM
  Pelican Parts Technical Article Directory    Reply With Quote #9 (permalink)
canna change law physics
red-beard's Avatar
All Honda engines have the same problem after a while. Notice, that if you choke the engine, it runs fine. You have an air leak and I've had the same problem trying to fix it. I expect I will buy a new carb to fix mine.
James
Red-beard for President, 2020
Old 10-25-2009, 11:54 AM
  Pelican Parts Technical Article Directory    Reply With Quote #10 (permalink)
If you need a manual or parts diagram look here
Honda Engines Europe EEC
Rick
88 Cab
Old 10-25-2009, 07:51 PM
  Pelican Parts Technical Article Directory    Reply With Quote #11 (permalink)
madmmac's Avatar
Not knowing the engine, but a lot of small engines have fuel lines now.
The problem arises when you give it full throttle, the "old" fuel line compresses, pinching off the fuel flow and this causes the carb to run lean....you put the choke on and it runs fine.
If not that, it does sound like an air leak somewhere.
madmmac AKA Mitch
1984 Factory Turbo Look
2006 4Runner
1998 TRD Supercharged 4Runner (Sleeper)
Old 10-25-2009, 11:13 PM
  Pelican Parts Technical Article Directory    Reply With Quote #12 (permalink)
Copyright 2017 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
