-   -   LED/LCD TV Tech-Question (http://forums.pelicanparts.com/off-topic-discussions/510505-led-lcd-tv-tech-question.html)
asphaltgambler 11-12-2009 12:34 PM
I am fairly sure I am ready to pull the trigger on a new 55" LG LED/LCD TV from Best Buy. so two questions:
1) This is a 240hz set which is @$300.00 higher than the next LG model with with 120hz - Is the difference in refresh rate at that speed really noticeable? (Especially for $300 more?)
2) Best Buy says that every LCD TV needs to be "calibrated" for (@$250) additonal for optimal performance - I say BS I can follow the manual for optimal settings per manufacturer through the guide-setup option.
Advice please.................
legion 11-12-2009 12:39 PM
I can't tell the difference in refresh rates.
You can buy a $30 DVD to calibrate your TV yourself. They are charging you $250 for $20 worth of work. It's just like their "insurance" in that they are overcharging you for the service by over 1000%.
asphaltgambler 11-12-2009 12:43 PM
Please elaborate on the DVD
legion 11-12-2009 12:46 PM
Something like this:
http://www.amazon.com/Monster-ISF-HDTV-Calibration-Wizard/dp/B000EEXEIW/ref=sr_1_1?ie=UTF8&s=electronics&qid=1258058762&sr =8-1
BTW, I could tell the difference between 60 hz and 120 hz, but I can no longer tell the difference above 120 hz. I used to up the refresh rate on all of my work computers as high as they would go...
asphaltgambler 11-12-2009 02:00 PM
No I think the BB tech guy uses some hand-held device to calibrate..............?? Anyone know this??
gprsh924 11-12-2009 02:28 PM
The guy who installed my cable tweaked a couple of the settings on my tv and it looks fantastic. I would not spend $250 to have someone calibrate it.
gr8fl4porsche 11-12-2009 02:42 PM
If you can use a remote control, you can calibrate your TV.
red-beard 11-12-2009 02:47 PM
I'm waiting for OLED. The "LED" TVs of today are really LCD with LED backlighting.
porsche4life 11-12-2009 02:49 PM
+1
I had the first creative labs mp3 player that had an OLED screen.... It was tiny and absolutely stunning....
imcarthur 11-12-2009 02:50 PM
Agreed. Buy a DVD & walk yourself through it. I use the AVIA disc to tune projectors & flatpanels with great success.
Ian
imcarthur 11-12-2009 02:59 PM
AVIA II
This is version II of what I have used for 10 years . . .
Ian
Gogar 11-12-2009 02:59 PM
Just remember, the 'refresh rate' of your eyeballs is about 68 Hz, FWIW.
60/120/240Hz does make a difference, but a very, very, very small difference.
