| speeder |
12-03-2009 07:34 AM |
Someone mentioned that this is the reason why they don't buy used cars, actually it's not a concern because it's so easy to check for this particular type of abuse/lack of maintenance. Any used car that I ever look at, one of the first things I do is open the oil cap and look at it and the inside of VC cover. On most engines, you can clearly see a rocker assembly or two plus part of the cam if the cap is directly on the VC. It gets harder to check if the engine has a long filler neck going to the VC but those are usually easily removable.
The great thing is that if an engine went for a long time between oil changes even once, the evidence is there. Black coloring and in extreme cases, sludge will be visible. In a properly maintained modern gasoline-powered engine, the valve train will be honey-colored or at worse brownish and absolutely clean of deposits. On diesels, black coloring is normal but there should be zero sludge. There are obviously several other tests and things to check, (blow-by, compression/leakage, etc.), and service records proving regular maintenance are always nice. But even w/o any records, a good eye can see a lot. Equally important on most engines is the condition of coolant passages and they are a lot harder to check than oil history. A history of clean, correct coolant is important on any engine but with aluminum it's life or death.
