-   -   Why Men shouldn't write advice columns... (http://forums.pelicanparts.com/off-topic-discussions/514424-why-men-shouldnt-write-advice-columns.html)
Rusty Heap 12-03-2009 07:18 AM
http://forums.pelicanparts.com/uploa...1259853432.jpg
Joeaksa 12-03-2009 08:59 AM
She might also check for water in the fuel tank...
legion 12-03-2009 09:52 AM
This is obvious. She should check the gauges behind the photo of her dog.
M.D. Holloway 12-03-2009 10:58 AM
ethanol is to blame...
herr_oberst 12-03-2009 11:11 AM
. . . she said it stalled, then it broke down? Does this mean she was able to get it running after it stalled? I'm thinking it might just be out of gas, because the implication is, as I read it, the car is still getting spark. . .
cmccuist 12-03-2009 11:52 AM
My advice - join in.
ckissick 12-03-2009 11:52 AM
Like a woman would be able to provide better automotive advice? Sheesh.
1990C4S 12-03-2009 01:05 PM
Sorry. Not believable, it has to be made up.
No woman would walk a mile for help. She might phone her husband who could be 100 miles away, and would be expected to repair the car with an hour. But she would never walk.
Laneco 12-03-2009 02:21 PM
Actually, the advice isn't really that good, especially for a non-car person...
When you have someone who knows nothing about cars tell you their car stopped running, the first thing you should do is ask them if they can smell anthing burning or smell fuel. If no, then have them turn on their headlamps.
If the lamps are extremely dim, the charging system is likely the issue (battery/cables and/or alt). If the lights are bright, crank the engine. Engine cranks normally indicates good battery charge, acceptable cable condition. Ask if they smell gas now (if yes - good chance fuel system is working but ignition becomes a likely suspect - they can't fix it either way, you're only satisfying your curiosity).
This is really all the further most inexperienced drivers can be safely expected to help you diagnose a repair over the phone. After this, have them turn on their four ways and start walking because most real beginners can't tell a vacuum line from an air conditioning line or an intake manifold from a brake reservoir.
angela
on2wheels52 12-03-2009 03:41 PM
"can't tell .... an intake manifold from a brake reservoir"
I have this line in my head "can't tell a camshaft from a quick-change (rear end).
Jim
gtc 12-03-2009 03:55 PM
+1
The columnist didn't even ask for pics of the neighbors daughter!
