Apple users: How do I stream music to my stereo?
And control with my iphone? I have the airport express and the iphone but thought I needed the apple tv to stream to my stereo--is there something else I can use? how did you do it?? Thanks
You have all the stuff... I am using this as we speak. Get a cable that goes from headphone to RCA and hook it up... Run the airport utility and setup your airport and open iTunes and click down in the lower right corner where it says computer and select your speakers... Voila...
Sidney--problem is my computer is upstairs and my stereo is downstairs so everything needs to be wireless--or am I reading your response wrong??
Have you got a wifi card in your computer? If so plug the airport in down by your stereo and hook it all up down there...
Shoot me a PM if you want my cell #.... I just went through this on tuesday... |
I use an Airport Express and a 3.5mm jack to RCA cable. Plug the 3.5mm side into the Airport and the RCA side into the stereo. Turn on iTunes and select the Airport as the play to option in the lower right corner. Not sure about the iPhone part.
Just realized I said exactly what Sidney already said.
All you gotta do for the iPhone is install the app called "remote". Inside that you click add library and it pops up a code... Hammer that into itunes over at the side where it says "devices"... Badda bing badda boom....
Your computer needs to have Airport enabled. Is it a Mac that came with it? I run iTunes on my iBook streaming via Airport to the Airport Express at my stereo, controlled by the Remote app on my iPhone that is sync-ed to iTunes on the iBook. Where it gets complicated is that the iPhone and iBook talk via Airport on a different wireless network than the Airport Express, working in tandem. Fortunately my wife has worked for Mac developers since Day One, but it still took her an hour to trouble-shoot the system. The best benefit has been the ability to use the iTunes EQ to adjust the output to suit the source material, speakers, and room!
I use the Remote app.
Real convenient. |
Doesn't have to be a Mac at the sending end.... XP works just fine.... Just wish my wifi card didn't suck... it keeps dropping the signal...
cool. thanks I'll try this too.
Or if you're really sassy and have digital inputs on your receiver, get one of these:
For only $2.09 each when QTY 50+ purchased - Toslink to Mini M/M OD:5.0mm, Molded Type - 6ft | Toslink to Mini Plug |
| All times are GMT -8. The time now is 03:52 PM. |
