-   -   Warped brake rotor... (http://forums.pelicanparts.com/off-topic-discussions/519501-warped-brake-rotor.html)
porsche4life 01-03-2010 11:14 AM
I seem to have warped one of the Rotors I bought new from Pelican in August... :( Is there any way I can fix it or is it a boat anchor now? Its got like 4k on it....
legion 01-03-2010 11:22 AM
You'll probably get more responses on the 944 forum, but....
It's my understanding that you can turn the NA rotors, if it's not warped too bad. Remove it and take it to your local NAPA. We're talking under $100 for the work.
porsche4life 01-03-2010 11:47 AM
Woops... Its on my VW... Little bitty bastard.....
fingpilot 01-03-2010 11:55 AM
Solid or vented? The only real way to know is to check runout. Can be done on the car, and a spec book will have the number. By the time you factor in the R&R (even yours) and the shop labor (you will want to do both of them) it might make more sense to live with it, or buy again.
Most warpage is from holding the brake after a 'vigourous' slow/stop. The heat of the caliper adds to the contact patch heat and warps that section only.
Most airlines prohibit parking brake after a landing or rejected T/O for that reason.
Good luck!
porsche4life 01-03-2010 12:03 PM
It shudders the whole car under braking is the only problem. I'm still trying to figure out how it got warped... I don't use the p brake when I know I've had the brakes hot... I'm not finding them on Pelican anymore... I only gave like 30 bucks for it IIRC. Now it looks like one is about 80 b/c Pelican doesn't have them...
cstreit 01-03-2010 02:31 PM
Warped rotors are very VERY rare (more of a myth really). More than likely it's uneven deposition of pad material. Burnish them very good with a whizzer or put in some aggressive compound brake pads. Make a few hard stops. Should cure it.
porsche4life 01-03-2010 02:33 PM
Explain burnish with a whizzer please.
TGTIW 01-03-2010 02:50 PM
I think he means you should pee on them.
Porsche-O-Phile 01-03-2010 03:15 PM
I agree. It takes an absurd amount of heat to warp the rotors. 944 rotors are pretty stocky too - even the n/a ones.
porsche4life 01-03-2010 03:15 PM
Jeff.... Its on a Corrado.....
9dreizig 01-03-2010 05:58 PM
Sid, regardless of what it's on,, you should go out and do some "spirited" starts/stops,, you can wipe the crap that's on them off. you might want to get a can of the spray on abrasive for brakes as well ...
porsche4life 01-03-2010 06:00 PM
So I need to go test the ABS? ;)
dad911 01-03-2010 06:09 PM
The "Warped" Brake Disc and Other Myths of the Braking System
