2000 BMW 528...speedometer quit working
Tried posting in the BMW side of pelican but not a lot of hands on input. Buddy has a 2000 528 and speedo began to work intermittently. Finally stopped working altogether. Is this likely the sensor? Is it located on the drive shaft? How to test rather than just throwing parts at it?
TIA jim
Jim 1987 Carrera 2002 BMW 525ti 1997 Buell Cyclone cafe project 1998 Buell S1W: "Angriest motorcycle I've ever ridden." |
I'm with Bill
Sensor in the diff. They break wires too.
Electrical problems on a pick-up will do that to a guy- 1990C4S |
Still Doin Time
Is the check engine light on? If not the cluster may have just pooped...........
'15 Dodge - 'Dango R/T Hauls groceries and Kinda Hauls *ss '07 Jeep SRT-8 - Hauls groceries and Hauls *ss Sold '85 Guards Red Targa - Almost finished after 17 years '95 Road King w/117ci - No time to ride, see above '77 Sportster Pro-Street Drag Bike w/93ci - Sold |
Friend of Warren
On the 3 series the speedometer gets its reading from the wheel speed sensor located on the passenger side rear wheel. You might also want to check the fuse. The speed sensor is number 5 in this parts diagram.
Kurt V No more Porsches, but a revolving number of motorcycles. |
Still Doin Time
- E39 ................5 series
Any other lights on??
Possible DSC control unit, speedo function runs thru the ABS
78 SC all over the shop 74 911 Stock |
I have had to replace the left rear speed sensor on two other bmw's to remedy the same problem ( one was a 740 il, and the other was a 3 series ) should all function the same way. I think that the abs light was on on the 7 series at the same time.
No left turn un stoned |
Sorry, may have been the right rear wheel, could not remember exactly .
