 Battery Charger Tech PPOT Electrical Brain Trust:  Our very nice fleet sized battery charger on wheels does not charge any more according to our mechanic.  A simple check with a dc volt meter shows 15 volts.  Could it be putting out some kind of (nominal?) voltage without any amps to back it up? Obviously I know not of which I speak... Go easy on me! |
 don't some of them "sense" the required charging strength?  like if there are no cells to charge, it goes to a lower setting?  i think thats how the digitally controlled ones work.  check by putting the meter inline, on a HIGH setting at first, on a dead or LOW battery. |
 your meter on a high setting i mean, to protect it.  most handhelds are too small for this, unless its a (insert that famous meter name here)professional type. |
 My small protable charger does not take a charge anymore when I plug it in overnight. What could be the problem? |
 i know several guys who have cut open the case on those 12 volt portable units and wired in a 12 volt trickle charger. |
| All times are GMT -8. The time now is 11:12 AM. |
