vash's Avatar
4x4 guys. yanking a stuck vehicle out. forward gears, or reverse?
any dangers to a tranny or transfer case if we pull in reverse? heard chatter that reverse gears are more delicate...any truth?
poof! gone
Old 01-30-2010, 07:31 AM
Banned
m21sniper's Avatar
Reverse usually doubles as 1st. Some manufacturers may be weaker, but as a general rule it shouldn't make much of a difference? I've seen M88's pull M1 Abrams out of ditches in reverse.
Old 01-30-2010, 07:33 AM
gprsh924's Avatar
I've done both a number of times with no ill-effects, but I can't answer your actual question
Garrett
Living and Thriving
Old 01-30-2010, 07:38 AM
I'm with Bill
Rick V's Avatar
As long as you can keep your wheel hoping under control, you should be okay, either direction. The one exception is when pulling with a Ford, with a 9inch rear. They like to break the diff. case right at the front bearing, when sudden changes in torque are applied in reverse. Just use your head and you will be fine
Old 01-30-2010, 07:44 AM
LWJ LWJ is online now
The only consideration is that the rear end of the pulling vehicle (which would be front if in reverse) is now taking a considerable more load than the front. Back when I had a landcruiser, it was said by those smarter than me that this was a great way to break the less strong parts in the front. Back axles tend to be beefier. I don't think gears make a difference.
BTW, I've done it both ways with no ill effects.
Larry
Old 01-30-2010, 08:38 AM
wreckersteve's Avatar
When pulling backwards the load is on the back of the gear teeth and are weaker. But the weight f the motor can give you more traction. It is better to pull forwards also so if the strap breaks it is less likely to come through the windsheild. Unless you have a pickup with no cap or backdoores, then your just as un protected.
The military stuff have Rockwells that load from top and really are just as strong from any direction.
2011 Wrangler Unlimited X
Old 01-30-2010, 09:20 AM
Bingo.
Although, reverse is generally a lower gear than 1st, so you'll get more torque.
Honestly, the question is too vague. What is pulling what from where. If you're yanking a basic pickup with a basic Jeep from a basic mudhole, then technique is all that matters, you won't break anything. If you add off camber, up hill, broken axles on the bad vehicle, great weight difference...then it becomes much more of an issue.
Also, if you're yanking with something that has independent suspension, then you'll break the half shafts before the differential. If you have lockers, you'll break that. If the pulling vehicle is old/poorly maintained, you could break just about anything.
Mike Bradshaw
1980 911SC sunroof coupe, silver/black
Putting the sick back into sycophant!
Old 01-30-2010, 09:33 AM
1.367m later
KevinP73's Avatar
Send a message via Yahoo to KevinP73
non velox ad propitiare, verisimile non oblivisci
If it's not The Original Automotive Innovations and Restoration, then it's just hot AIR.
Old 01-30-2010, 10:56 AM
"YOU CANT RACE A CAB."
ODDJOB UNO's Avatar
theres this thang called a WINCH available you might try. hear they werk real well.
Old 01-30-2010, 04:04 PM
vash's Avatar
i grew up with a ramsey winch. life saver for the most parts..i dont like all the winch bumpers for tacomas...my ramsey was on my jeep.
poof! gone
Old 01-30-2010, 04:09 PM
Habitual User
BLEW911's Avatar
pull frontwards,low range,no need to speed.
'80 911 Targa
Old 01-30-2010, 04:28 PM
what are you pulling out, a fullsize truck? You should be fine neither direction. Low range, and make sure you have enough weigh on the bed for a bit more traction. I pulled out my buddy's full size van that went into a ditch up in Mammoth with my little 22RE 4 banger Toyota pick up in reverse. I didn't think I was going to be able to pull it out. With him on the gas as soon as I yanked him lose, I basically towed him up the little hill onto the road backwards. You should be fine.
Old 01-31-2010, 08:55 PM
Non Compos Mentis
Real 4x4s are built with pretty stout components. For an "average" pull, you're fine either way.
As conditions get more difficult (steep, deep mud, sideways pull, yada yada...) just know that the front will break before the rear, and pulling backwards does put the strain in ways different from what the components were designed for.
I've done both, but if it looks difficult, I alwayd pull with my truck forward.
Old 01-31-2010, 09:02 PM
