-   -   100x more confusing that modifying a 911 suspension..lifting/modding a truck! (http://forums.pelicanparts.com/off-topic-discussions/524830-100x-more-confusing-modifying-911-suspension-lifting-modding-truck.html)
vash 02-04-2010 09:08 AM
damn. i thought i outgrew the urge to lift a truck. my last rig, was a Cj-7. easy.
i took my truck on an offroad camping trip. one section was a series of boulders, and baby heads. my truck did decent. but i almost smashed my door in. my tires also rubbed hard against fenders, and my rear suspension bottomed out with a moderately light load of camping gear. i need a itsy bitsy, teenytiny..2" of lift. 2 inches should be cake. SOB has the industry changed! i dont even know what i am shopping for anymore. maybe i will just play dumb and farm the entire job out.
i want to keep my stock wheels and tires. no ring/pinion work. looking at a OME or toytec lift.
anyone lift their toyota tacomas?
robs944 02-04-2010 10:05 AM
Hey vash
I put a 3" RevTek suspension on my 01 Double Cab Tacoma, kept stock 16's and have on 265/75 BFG A/T
When I shopped for mine I felt the same you do :confused:
I don't think there is a "2" suspension kit" for your truck only 2" body lift, if doing a suspension I think 3" is the minimum.
You could do an add a leaf kit and some bilstein adjustables up front to level it out?
That should give you the lift your looking for.
emcon5 02-04-2010 10:06 AM
Dumb question, is there still a TRD Off Road package for Tacomas? My Tacoma is a 98, but I believe it is a little higher with the TRD package than a standard 4X4 of that year.
I could be mistaken though.
Tom
Shawn 357 02-04-2010 10:14 AM
I haven't lifted a Tacoma but I am no stranger to lifts. Ten years ago the options were body lifts, drop brackets, and how many shocks you want on each wheel if you wanted to get fancy:)
Now there are a lot of options that include control arms, coil overs, spindles, even bypasses!
Are you looking just for a little more height or are you trying to make the suspension work better? What year is your yoda?
Toyotech and Allpro make bolt in adjustable struts for Tacomas. Those struts plus some blocks in the back or an add a leaf...
robs944 02-04-2010 10:40 AM
I stand corrected I just found this (uses spacers up front instead of adjustables)
Kit runs about $150
Toyota 2.25" Lift & Leveling Kit 4WD/2WD (6-Lug) 2005-2010
2.25 Inch Front Spacers and 2 Inch Rear Add A Leafs
http://forums.pelicanparts.com/uploa...1265308651.jpg
They also make one that uses the blocks in back instead of the leafs.
vash 02-04-2010 11:06 AM
think this route?
Complete OME suspension Includes: $699.99
Front OME N140S shocks
Front coils: 885
Add top plate spacers for a full 3" front lift with 884 and 885 coils
ToyTec add-a-leafs
Rear N182 shocks
Front diff drop kit for 4x4 models
OME trim spacer for a level front.
but ditch the top plate spacer to keep it under 3". i may need to add upper control arms, and rear diff shims. right?
argh! confusing.
HHI944 02-04-2010 11:13 AM
No experience with a tacoma, but I've got OME springs on my Rover and they are a great product. Gave about an inch of lift in front and 3 in back and a much nicer ride on or off road than OEM.
craigster59 02-04-2010 12:01 PM
Cliff, Try here. They have lots of kits and if you scroll down to "tech specs" you can view a PDF of installation instructions so you know what you're getting into.
Toyota Tacoma Lift Kit 2005-2010 4x4 - 3" Kits (# 52907) Tuff Country Suspension
IROC 02-04-2010 12:11 PM
I just did this to my DoubleCab. Sway-A-Way adjustable coilovers in front and add-a-leafs in the rear. About 1.5" - 2" of lift. I bought all of the stuff from Wheeler's Offroad. I went with 265/75-16 Yokohama all-terrains.
The ride is great and the installation was very easy.
http://forums.pelicanparts.com/uploa...1265314198.jpg
http://forums.pelicanparts.com/uploa...1265314217.jpg
924slover 02-04-2010 12:17 PM
Toyotas are harder to lift because they have ifs which is harder and more exspensive to lift the easiest way to get an inch or two is to do a t bar crank but you then have to have an alignment and you have a slightly harsher ride. With my old s10 i just did a t bar crank and spacers in the rear and that gave me 2-3 inches more clearance. ifs is NOT meant for rock crawling it's just not tough enough.
legion 02-04-2010 12:18 PM
I've always wondered how lifting a truck affects the steering geometry.
I'd also think that if you lift a truck enough, you have to lengthen the driveshafts and the steering column. I also have no idea how you lift the front suspension.
IROC 02-04-2010 12:29 PM
Toyota abandoned torsion bars in the front a long time ago. BTDT. I put larger torsion bars on an '87 4Runner back in the day and cranked up the height. The ride was actually better than stock.
Lifting the front now is extemely easy with adjustable coilovers. Four bolts on each side and they're on. It probably took me two hours start to finish.
Changes in alignment, steering, etc. are a non-issue unless you're talking some serious lifts and then you're not worried about street driveability anyway - you've got a dedicated rockcrawler.
vash 02-04-2010 12:33 PM
i just got invited to a toyota "mod day". 3 trucks that are getting suspension jobs...free. i'll be there with my lucky wrench and camera. this can't be any harder than the rear of our 911's, right?
ODDJOB UNO 02-04-2010 12:44 PM
bottomline............make this simple. BUY TRD parts only. or go simpler route with sway away and add aleafs.
why because i know IVAN STEWART PERSONALLY AND HAVE DRANK MUCHO CERVEZAS with him!
do you frigging know how much engineerring pesos get spent on suspension?
the daze of straight axle spring/block lifts are over.
on both of my IFS GM vehicles my front end guy (network alignment here phx.) told me how he gets rich off of dumbass POS lifts.
simple suspension for IFS.
sway away torsion bars HD
pair of add a leafs in rear
or go TRD route. simple werks and NO CLUSTER FEEK.
take a look at TOYOTA SCORE CLASS 7 and 7S trucks. then you will be in the KNOW!
bell 02-04-2010 12:46 PM
I regularly lift trucks....from 3"-12"......and have a done quite a few tacomas.....I'll post some info when I get home from work
vash 03-02-2010 01:08 PM
parts ordered. i plan for nose bleed elevation gains of two inches!!
gonna be easy, without all that reindexing BS.
Hoots 03-02-2010 01:36 PM
All the info you need
TTORA
vash 03-02-2010 01:39 PM
^ some aggressive folks on that site.
vash 03-14-2010 10:49 PM
done!! had a buddy with a spring compressor help.
http://forums.pelicanparts.com/uploa...1268632187.jpg
porsche4life 03-14-2010 10:51 PM
Good looking truck....
Just needs to be red....
