-   -   power adapter cord polarity -- help (http://forums.pelicanparts.com/off-topic-discussions/525293-power-adapter-cord-polarity-help.html)
Sapporo Guy 02-06-2010 10:52 PM
Ok, been googling for a while ... I figured you'all be smarter :D
http://forums.pelicanparts.com/uploa...1265525363.jpg
Which wire is negative ? black or b/w
lolo, that will answer the which wire is positive ;)
Just FYI, I'm working on a carpc SmileWavy
The actual suspect wire
http://forums.pelicanparts.com/uploa...1265525454.jpg
Which is gonna be plugged into an adapter and into my voom pc case that is using a mtx-3 psu.
still trying to figure out the wiring part since I bought the parts used ... manuals only help so much...
Thanks!
dad911 02-07-2010 05:18 AM
Could be either. I wouldn't take a chance supplying reverse polarity to electronics.
Plug in the adapter and measure it with a voltmeter.
imcarthur 02-07-2010 05:18 AM
In the top pic, the inner contact is positive (hot). The little diagram on the adapter tells you that & I am sure a DC voltage tester would confirm. But with crimp on connectors, I could only guess . . . test it with a voltage tester before you power it up (or blow something up) imho.
Ian
Joeaksa 02-07-2010 07:23 AM
Usually the wire with the white stripe is positive.
Get a VOM and make sure!
Sapporo Guy 02-08-2010 07:25 AM
Thanks guys!
For the reasons you guys have given I figured I'd rather be laughed at for being a noob than be laughed at for firing my car pc mobo :)
ooops, should have posted that the 2nd picture is of the crimp connectors coming from the coaxial connectors not the actual adapter.
Idea is to use the above connection to go between a regular pc type of power adapter and the mobo molex connector.
Will do on the voltmeter .... lolo, gotta learn some more on that :)
Sapporo Guy 02-08-2010 06:31 PM
firing ... lolololo
Frying ;)
Oracle 02-11-2010 10:52 PM
Easy, use an old speaker.
One way the cone will go down and the reverse will go up.
The proper polarity will be on the latter. (the + or - are indicated in the speaker connectors)
slodave 02-11-2010 10:57 PM
After learning the hard way, I'd agree with Joe... I do check with a voltmeter first anyway now though. :)
