sausage making
Guys, I made these sausages
![]() ![]() I mixed and ground up 700 grams (a couple of pounds) of wild venison, about the same amount of pork belly, two teaspoons of crushed fennel seeds, 2 teaspoons of coarsely ground pepper, a teaspoon of salt, quarter of a cup of Barkers High Country sauce (a local spicy and chilly tomatoe sauce), ten - yes ten cloves of garlic and half a cup of water. Then put it through this sausage stuffer that I bought off our version of ebay. ![]() The sausage skin get stacked up over the plastic end of the stuffer and you wind the handle, and out it comes - as easy as that. I did the ultimate sausage test by having some friends around and cooked them on the char grill bbq and the results were excellent. If you are curious, yes it was me who shot the deer but it died for a good cause. |
i'm just a cook
they look great.
Hopefully this doesn't start a "Show me your sausage" thread.....
Rob Black 1983 911 SC Coupe |
Senior Member
Looks very good. What did you use for the casing?
2021 Subaru Legacy, 2002 Dodge Ram 2500 Cummins (the workhorse), 1992 Jaguar XJ S-3 V-12 VDP (one of only 100 examples made), 1969 Jaguar XJ (been in the family since new), 1985 911 Targa backdated to 1973 RS specs with a 3.6 shoehorned in the back, 1959 Austin Healey Sprite (former SCCA H-Prod), 1995 BMW R1100RSL, 1971 & '72 BMW R75/5 "Toaster," Ural Tourist w/sidecar, 1949 Aeronca Sedan / QB |
Just thinking out loud
Have run several thousand pounds of venison through this one.
![]() I use pig intestines for casing and old plantation for seasoning. 60/40 mix (pork being 40)
83 944 91 FJ80 84 Ram Charger (now gone) |
Yum!
Did you drop the deer yourself? Those photos bring back great old-home memories.
Don . "Fully integrated people, in their transparency, tend to not be subject to mechanisms of defense, disguise, deceit, and fraudulence." - - Don R. 1994, an excerpt from My Ass From a Hole in the Ground - A Comparative View |
Hi Bill,
We live on a small farm and slaughter our own cattle for meat and we make our own sausages. Much better than the ones from the butcher and we can spice it to our liking After we mixed the salt and spices in we cook a small sample it the micro wave for everybody to approve of the mix. We use a slightly different gadget to stuff the casings which we buy at the butcher . The casings are either artificial or recycled animal intestine. Spannerman my grandson demonstrates how they were opened in the olden days but it should only be filled with brine to unfold it and than leaks out on the other side After I learned about Jerky here I can tell you we also dry some of these sausages similar to jerky ( biltong ). ![]() ![]() Cheers Baron |
![]() I asked my local butcher for casings. I think it's pork intestines. Quote:
Baron, that's a nice big quantity. Looks good too. I'll try a bigger batch next time. |
Congratulations!
![]() Fast bullet; used it to drop large varmints back in North Dakota (early '60's).
A Man of Wealth and Taste
Who do U Boyz think you are Sarah Palin?
Copyright "Some Observer" |
Getting ready to make 15 lbs of "boerewors" (from South Africa literally farmers sausage) tomorrow. Mostly beef with a little pork but I think I will add some venison as well. Great on the grill!
Neil 87 944S http://guns.claasen.us/ |
Senior Member
Its a good round only as long as its not windy, not too long a shot and no brush or the like to get in the way. A .270 or 30.06 is a lot better IMHO...
I aspire to be as manly as her. I thought huntin' n' shootin' was a good start and work my way up to wrestling grizzly bears.
Neil, if you wouldn't mind posting the recipe here it would be much appreciated. I spent three months in South Africa (surfing J-Bay and driving around) so I know what a good boerewors tastes like. The ones I buy around here are rubbish. |
Best.
1996 FJ80. |
I have to translate it, so I will post it sometime tomorrow. Who knows, maybe it becomes popular in the USA and I can just buy it at a local store like I used to in South Africa.
Now in 993 land ...
![]() George
Detached Member
That's great. I'll take 700 grams, and I'll even pay for it.
Hugh |
I almost forgot about this! Here is the recipe. It is taken from an old Afrikaans recipe book that is very common in households in South Africa (well, Afrikaans ones at least)
10 lb beef 2 lb pork 3 lb bacon (I use fresh side) 1 tbsp pepper 3 tbsp salt 2 tbsp fine ground coriander 1 tbsp ground cloves 1 ¾ tbsp fine ground allspice 1 ½ tsp nutmeg 2/3 cup white vinegar Method: Grind beef and pork and mix together. Cut bacon into small cubes and add to beef/pork mixture. Mix all dry spices well, sprinkle over meat mixture. Thoroughly work spices into meat, add vinegar, work through and let stand for 1 hour. Mix before stuffing into clean casings. Grill on fire or in pan. A few notes: I am sure you can used cured bacon as well but that will change the taste obviously. My butcher supplies me the meat (beef and pork) that he uses when making ground beef/pork. I prefer to grind this myself as I like a slightly coarser ground than what you find in store bought ground meat. I have however used pre-ground meat before (although it is easy to stuff the mix in too tightly then). I have halved the recipe before without any problems. Of course, the best way to enjoy it is grilled on a charcoal or wood fire. To me the coriander and cloves is what gives this it's distinctive taste and is probably used in most variations of this you can find in SA.
Mooi blay (excuse my attempt at Afrikaans spelling spelling Neil).
Not too bad for a Kiwi. Hope you enjoy it. Sub zero temps be damned, I am grilling some tonight!
