-   -   Fire codes. (http://forums.pelicanparts.com/off-topic-discussions/537715-fire-codes.html)
tcar 04-20-2010 01:15 PM
They're probably thinking that eventually, the wood chocks will catch fire and burn, letting the doors swing shut.
Zeke 04-20-2010 02:14 PM
Originally Posted by Jim Bremner (Post 5305233)
Ok,
Next code please!
I have a steel roll up door that I do not use. What can I insulate the door with to stop it from heating up my warehouse? I had planned on expanded Styrofoam sheets from Home Depot. Any suggestions?
You need to show the type of door. You mention sheets, so I suspect it could be a sectional door. If it's a corrugated roll up, you won't be using the sheets and keeping the door operational.
That being said, a large door that opens slowly with an endless chain loop could hardly be considered a fire egress door.
There are 2 types of insulation that pertain to your situation. Conduction and convection. Sealing the edges against air movement is the latter. I assume you are interested in the former.
Two ways to do that as I see it. Your way with the foam sheets, or you could hang a soft barrier outside of the door to reflect the heat away from the exterior surface. The 2nd method will allow the door to be used if needed w/o any difficulty.
One of those silver faced tarps would be perfect for the job. Just make sure some air can circulate behind the tarp between it and the door surface.
