-   -   How to safely remove the rings from an Audi decklid? (http://forums.pelicanparts.com/off-topic-discussions/542391-how-safely-remove-rings-audi-decklid.html)
Garp 05-14-2010 12:39 PM
The rings on the decklid of my Audi have become quite pitted and in fact bubbly. I'd like to remove them, any tricks for doing this?
I also would like to know why they used such cheap plastic for these 'chromed parts', same for the front grill. :confused:
Bob Goding 05-14-2010 12:44 PM
Its just double sided sticky tape----careful use of a heat gun should do it.----depending on the colour,there may be unfaded markout on the paint.
Quality of the item is known as 'planned obsolescence'-----you are supposed to buy a later model car!
stomachmonkey 05-14-2010 12:48 PM
Little bit of warmth and fishing line.
Googone to get the residue.
Heel n Toe 05-14-2010 12:57 PM
Heat gun could be a bit difficult to keep from putting too much heat in play. Try it with a blow dryer first... with an attachment that pinches down the air flow to a smaller stream if possible.
Don't know if the rings were plastic, but last week on Ultimate Factories, they did an hour on the Audi R8... and showed the same doublesided sticky attachment method.
Lazarro 05-14-2010 01:42 PM
Dental floss and Goo-gone.
nostatic 05-14-2010 01:49 PM
sawzall
Tyson Schmidt 05-14-2010 02:21 PM
I don't know, but you'll need a ring compressor to reinstall them.
Hugh R 05-14-2010 03:50 PM
Dental floss works really well for that.
LeeH 05-14-2010 04:20 PM
Youtube... my favorite teacher.
<object width="640" height="385"><param name="movie" value="http://www.youtube.com/v/5saNP7cdFck&hl=en_US&fs=1&"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/5saNP7cdFck&hl=en_US&fs=1&" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="640" height="385"></embed></object>
Garp 05-14-2010 10:32 PM
Tx for the advice guys. Much appreciated.
porsche4life 05-15-2010 02:33 PM
Plastic explosive.... its really the only way to make sure you get rid of all the junk parts on an audi.... ;)
BGCarrera32 05-15-2010 07:30 PM
Given that it's an Audi:
1) Obtain Bentley manual
2) Disconnect negative battery cable
3) Spend 45 minutes figuring out how to unsnap the front bumper
4) Remove 19 unnecessary plastic clips from some wiring harness
5) Surf the stupid AudiWorld forum
6) Print off technical posting on how to remove the emblem
Tim Hancock 05-16-2010 06:35 AM
:D You read my mind. :D
poorsche930 05-16-2010 10:57 AM
7) When all else fails go get insulted by emo kids on vwvortex.com
You missed one! :D
