-   -   Toyota 4.7 V8 2001 Seqoia - common issues? (http://forums.pelicanparts.com/off-topic-discussions/545932-toyota-4-7-v8-2001-seqoia-common-issues.html)
aigel 06-02-2010 09:58 PM
Shopping for a "new" SUV. The Sequoia seems nice. How about the power plant - 4.7 l V8. Is this any good? If not, what are common issues? Anything to check when doing my PPI (DIY)?
Thanks,
George
89911 06-03-2010 04:54 AM
I posted some experiences with my 2002 Sequoia. Overall, not a bad car. The worse points are that it is somewhat underpowered, a four speed transmission, and the gas milage is poor.
http://forums.pelicanparts.com/off-topic-discussions/483558-toyota-sequoia-decent-family-hauler-tow-vehicle.html
NICKG 06-03-2010 05:09 AM
ac compressors are pretty notorious for going kablammo...
aigel 06-03-2010 07:13 AM
Unfortunately gas is too cheap right now. These were very cheap when gas was $5.
Does the V8 have chains or belts? What is the belt service interval, if it has belts?
Thanks,
George
Flyer88 06-03-2010 09:56 AM
It's a belt. I have 107K on my 2004 . Did the 90K service, replaced an oil pressure sending unit ($40) and just replaced an 02 sensor ($95). Other that that just tires, brakes and oil.
sammyg2 06-03-2010 10:50 AM
I had a 2001 tundra with that engine, bullet-proof. Never a single problem with it, although I only put around 70k on it before I traded it in on a new tundra.
I did no maintenance at all on that engine besides oil and filters because that was all that was necessary or required.
ths911 06-03-2010 10:58 AM
I had a 2002 Sequoia for 5 years. nice vehicle - oil changes, air filters, brakes and tires only for the 90k miles I put on it. Only complaint - poor gas mileage especially when towing.
t-tom 06-03-2010 12:18 PM
I have an 01 Tundra with that motor. I've got right at 85K on it and have not had a single problem. Just oil and filters.
aigel 06-03-2010 12:54 PM
Thanks everyone for chiming in.
Belt service is probably a $1k item at the dealer / independent shop from what I gather? Need to make sure I deduct enough on the price if it doesn't have receipts.
Is it an interference engine?
Thanks,
George
kaisen 06-03-2010 01:19 PM
Yes, it's interference.
Why a Sequoia?
aigel 06-03-2010 02:49 PM
Need a full size SUV for a good price quick and looking only locally minimizing travel time. I am not set on a make and model, but the older American stuff is pretty worn out on the interiors and I am staying away from the Expeditions due to bad experiences with an F150 of similar vintage.
George
aigel 06-04-2010 01:38 AM
Bougth the SUV. I was able to negotiate a very good price due to the timing belt needing changing. Not a terribly big job. That engine compartment has a lot of space - almost old school. All of the power options worked - amazing. ;)
Unless gas goes to $5 this appears to be something that I could always sell for little loss.
I'll get busy with it over the next few weeks. Needs tires, shocks, timing belt. I will also go through the cooling system and all other fluids while I am at it.
The brakes are pretty anemic. Anything that can be done to give them a bit more bite?
George
aigel 06-05-2010 11:20 PM
Well, add a cracked exhaust manifold to the list of things to do (thank the lord for good access). Appears a common problem. I noticed an exhaust leak noise on the test drive but wasn't up to speed on this being a common issue. My guess was a donut gasket ...
The brakes can be upgraded to 03 specs which supposedly helps. So far the first 100 miles were uneventful.
I found a lot of people with 130k on the first belt (one lady with 400k) so no rush on the timing belt either, IMHO.
Thanks again everyone!
George
vash 06-06-2010 12:10 AM
its a great rig. have fun with it.
