House reno design challenge
I'm having drain tile done, replacing a foundation wall on the garage, and redoing all the landscaping around my house. While it's torn apart, I'm also having them pour footings between the house & garage, pour a pad and frame up between the house & garage. THis will be a HUGE improvement to the house, allowing easy (and inside) access to the finished loft above the garage.
Here is what I have right now: http://forums.pelicanparts.com/uploa...1276103401.jpg We've got enough brick pavers to make the main landing a really nice patio area. We need to come up with a design for: -Windows and doors for the new enclosed breezeway -stairs leading from the patio up to the new breezeway (4 steps) -stairs going down to the driveway (2, maybe 3 steps) Here is a "blank slate" that I'm using to draw up some ideas: http://forums.pelicanparts.com/uploa...1276104465.jpg Ideas? |
Seating and a stripper pole?
INclude a BBQ and a sink somewhere in the plan. Out door Kitchens / bbqs are huge in the
upper end homes here in CA. |
Needs a rotating platform and a lift so you can double stack them.
MBM - Box Car System - Lift parking systems http://www.mbmbox.com/images/prodott...aforma_360.jpg http://www.mbmbox.com/images/db_cover_a1b1.jpg What's that box with access doors doing there? Looks too tight to me. |
I was involved in a project a couple years back that called for a elongated fire pit at the edge of a deck that acted as a fence. There's photo I posted in the kitchen cabinet thread. You might think about that as well for the other side or even an out door fire place. I will try to get a pic of my fire pit for you when I have a chance.
You seem to have a lot of room on you property so you can do a lot of interesting things in terms of design. Ulike here in LA, but we still manage to cramp them in there to make it work. Space planning is king here. |
I'm assuming from the light that the existing red door faces west?.....
And there will be no carport and/or car access?.... And that box is for some kind of storage, and doesn't block up an existing basement exit? You're going to end up with a big blank wall if the carport is filled in. You need to get some light in that transition, and possibly put some curves on the outside. Here's one idea: http://forums.pelicanparts.com/uploa...1276112423.jpg |
You could also put french doors and make a walk-out patio with benches/grill, but next to a garage it's a little wierd(except for men I suppose).
Here's another pic of the area: http://forums.pelicanparts.com/uploa...1275940402.jpg Here are some pics from when we bought the house: http://forums.pelicanparts.com/uploa...1276113503.jpg http://forums.pelicanparts.com/uploa...1276113491.jpg Quote:
Great stuff, thanks! |
Based on yet another assumption (lack of information and context); 1. Simple glass and wood entry/breezeway to preserve the existing architecture. 2. Grand steps with generous landing platform with chairs and potted plants which can be placed off the main egress path offering the visitor a welcoming stage. Will need a handrail on one side and some lighting with motion detectors for safety. That's all you are getting out of me unless I see some checks coming my way.;) http://forums.pelicanparts.com/uploa...1276114967.jpg |
Not enough info.
What is the breezeway used for now? Is that how people get from garage to house? When you enter the red door, what's there? Is that the main/only entrance to the house, or is there a main/formal front door somewhere else? Does your weather suck or is it nice? Where is south, where is the sun? Does wind currently whip through that tunnel or is it sheltered? Do you already have plenty of patio space? Do/will you need ramp (handicap) access? What problem/need are you trying to solve/address? Or are you simply looking to fill the hole with something better-looking? My 2/10th of a cent, without actually any info, is -> if the house doesn't have a well-defined main entrance, I'd make one. If the wall between the red door and the basement access is the logical place, then the area you've dug up seems big enough for broad steps, an entry deck/porch, something to frame the entrance. Or, the breezeway could itself be the made into a main entrance, assuming the red door leads somewhere appropriate, not to a kitchen or mudroom. My impression is that this is a nice big house with that grand tree and all that beautiful shake. It needs an entrance with some drama and grandeur. |
And yeah, where this is the primary focus when you arrive, we want something prettier. Quote:
http://forums.pelicanparts.com/uploa...1276139956.jpg |
Ahh yes...
Can't forget the VW fire pit. |
| All times are GMT -8. The time now is 10:11 AM. |
