Gold standard for water proofing basement?
More specifically the connection between the concrete slab and the walls (concrete blocks). I know it would be best to have poured concrete walls but that doesn't fit us at this stage. The basement walls can be covered with water repellent products or with an EPDM sheet, still to be decided but it's the transition that I'm a bit worried about.
A draining tube is foreseen around the basement and the slab has just been poured. |
This is what we did, guaranteed for thelife of your home
Basement Waterproofing Information and Estimates | Wet Basement Contractors |
Backhoe and 20 tons of crushed rock did it for me. Gold standard means water doesn't come in.
Larry |
Edit: Re-read your original post. Are you saying that the walls are going to be built on the basement floor? That is not how it is done around here. We pour a footing, build the walls, then pour the slab after the walls are up. If they are building the walls on top of the floor, how are they tied together? Rebar? Can you post a picture? |
Tx guys, interesting reads.
+1 on the W.R. Grace products
Xypex also makes a good waterproofing for CMU also look for "Sonneborn HLM 5000", it is a trowel applied waterproofing membrane that works well |
Decided to go with a poured concrete set-up after all.
http://img820.imageshack.us/img820/7885/img0176k.jpg http://img36.imageshack.us/img36/7608/img0184dl.jpg |
You still have a dry joint.
water will still weep thru concrete, you need to waterproof the wall and especially the joint to the existing brick wall - +1 what Milt said
You either give the water some where else/preferable to go, or you build a ship hull for a basement. ...and let the house rise with the tide, so to speak.
| All times are GMT -8. The time now is 01:28 AM. |
