Help me fix my blender!
It's an Oster In2itive.
We tried to run it, must have been piece of ice jammed in it, it tried to start up and jammed and died instantly. I've read up on it ,and there is apparently a fuse in it somewhere. It seems like that fuse blew. Prob is, I don't see anything that looks like a fuse. Take a look, is there a fuse there? http://forums.pelicanparts.com/uploa...1281820631.jpg http://forums.pelicanparts.com/uploa...1281820694.jpg http://forums.pelicanparts.com/uploa...1281820720.jpg |
I see the problem. You have the 12 blade fan. You need the 14 blade fan for better cooling.
well, that and he probably pulled a head stud...
no circuit reset (either on the board or for the AC outlet)? |
I don't see anything that looks like a circuit reset anywhere on it. There may be one, but I can't find it. |
(disclaimer: the following opinions shoud probably be filed in the round file).
Don't think the motor runs on 110V, so there's probably a reduction transformer in there. Black box?. Mabye it, or the fuse, is under the top board. The Mfgr or Radio Shack might be able to order it with correct specs. If there's a bump in the wire there could be a fuseable link. |
you might want to pull the board and look on the underside.
Or get a Waring :p |
Me thinks that some of you jokers need to stick your head in a blender! :)
Are there a total of 6 shims under that fan washer?
She really worked me over good
She was a credit to her gender She put me through some changes, Lord Sort of like a Waring blender |
The black box is a power relay that turns the motor on. Don't see a fuse in there. . . . .
There is no fuse visible. The black box is probably a relay as Gogar pointed out. Without a wiring diagram, all you can do is poke around with a voltage meter but success is doubtful . . . Ian |
Just for the sake of asking . . . did you try a different outlet?
I have seen fuses that look like diodes
Have you tried the blender forum? |
| All times are GMT -8. The time now is 06:34 AM. |
