A lot of old Rovers had them.
Lots of folks on the miata board want to install them. Unless it's a racecar or part of a larger system (as on the BMW mentioned above), then it's a useless gimmick that adds nothing. |
Strangely - my Pathfinder does not require a key so the FOB stays in your pocket BUT you turn the ignition switch just as you would any 'key' car. |
http://forums.pelicanparts.com/suppo...oilet_claw.gif |
The system on our Cayenne is pretty cool, though a little more conventional looking.
Put the key in the ignition, without turning it or anything, and it sounds like 2-3 deadbolts unlock behind the wheel. I'm guessing it'd be hard to move with them locked. Then you just twist the key to the right like normal, but just release it, and it cranks it only as long as it needs to to start the motor, you can't over or under crank it. |
when I was younger I used to own many cars that I had to push to start
- used to park on hills all the time too |
LOL I remember thoese days! Walking a extra few blocks for a hill.
bah, I push started my 914 lots of times, trick is to park on a hill.
$200 for a key/fob thing isn't bad... it was about $110 for a key for moms '97 M...
He was kind enough to push start me, though. |
It may be bling but there is one benefits I can think of.
Have you ever broken a key off in your cars ignition switch? I've never done it but I have fixed cars over the years with this problem. It's never easy. .................. Another reason why I got off the new car merry go round years ago. Save your money or invest wisely instead. |
Am I a dumb *****?
What's a "GIC for my RRSP"? :confused: |
RRSP = registered retirement savings program I've never bought a new car and I'm in better shape financially then most of my friends, including one who makes almost 3 times the money we do. P!sses him right off. I had a push button in one of my old bugs...screwed right to the dash. |
The company asphalt eater I sport has the push button ignition and keyless door system. I'm indifferent about it. While on one hand it is nice to not have to mess around with a key (I do lock it sometimes) to get in and take off, the other hand says it might deter theft of a Prius.
I leave it unlocked and running most of the day, in some really shady areas, and have done so in several different cities and towns across Texas, but the thieves have yet to touch it. Maybe I'll get lucky one day. |
I like the paddle shifter on 6 speed cars. Your shifting has pretty precise when six gates are crammed into the shift pattern. A lot of paddle cars are also dual clutch cars. My only experience with a direct comparison is a VW GTI with 6 spd vs on with the paddle shift dual clutch. I liked the paddle much better. |
I have a push button, but i still have to stick my dongle in the dash.
But a big point is overlooked here... having a push start button also makes it easier to optimize the start through electronics. You get in you push the button , done some people would floor the accelerator when cranking, some would pump the pedal, some would crank a bit to short, some to long.. etc etc.. No more of that , now you simply push the button. From an engine control point of view, it's better. Obviously you want a system that works, on a car that doesn't go loopy and on the run, with defunct brakes, but that's a whole different story... |
pfft....push buttons are nothing new. They used to be on the floor. One Buick model started when you pushed down on the gas pedal.
Lots of 50's British cars had them on the dash. Go back to the 30's and starters were activated in all different manners. I'll agree with the marketing thing. But, having replaced some key ignitions, I see the less moving parts as a plus. And whoever said push button starts and ignition are different, well, so? Whatever it takes to get going. |
| All times are GMT -8. The time now is 01:14 PM. |
