drag racing the short bus
Push-button ignition
I'm trying to figure out what the advantage is of push-button ignition. Why are so many manufacturers evolving to this? I feel the same about push-button ignition as I do paddle shifting or semi-auto/stick floor-mounted transmission: in short, "Why?"
Is it a legitimate improvement to the driving experience, or just marketing hype?
The Terror of Tiny Town |
one of gods prototypes
it's so when you lose your key you have to spend $200+ at the dealer to get a new transponder programmed to the car.......same applies if you want multiple keys......
Brought to you by Carl's Jr. |
Band.
I also imagine that the cost of manufacturing a key/tumbler is higher than a button.
The system in my wife's BMW is pretty cool. The key stays in your pocket and you just push the start button and release. Then the car takes over and starts the car. I understand that many (or all?) of the Japanese systems require you to hold the starter button until the car starts.
2014 Cayman S (track rat w/GT4 suspension) 1979 930 (475 rwhp at 0.95 bar) |
Cars & Coffee Killer
I always thought it was trendy because real race cars have a push-button ignition. Of course, the way it works in a race car is completely different (you have to turn on power to the ignition system then hold the start button for the starter to run). Also, every manufacturer seems to have a different take on how you have to turn off the engine if the car is in motion, leading to some deaths/bad accidents when people can't figure it out in a hurry.
Some Porsches long ago...then a wankle... 5 liters of VVT fury now -Chris "There is freedom in risk, just as there is oppression in security." |
Pfft. You guys are late to the party. My 1952 bug has push-button start.
"You go to the track with the Porsche you have, not the Porsche you wish you had." '03 E46 M3 '57 356A Various VWs |
Senior Member
Bling. Its for sales only on the newer cars.
Real cars, like the older Jag's and other Brit cars had them for years but they were not trying to show off then, it was considered normal.
2021 Subaru Legacy, 2002 Dodge Ram 2500 Cummins (the workhorse), 1992 Jaguar XJ S-3 V-12 VDP (one of only 100 examples made), 1969 Jaguar XJ (been in the family since new), 1985 911 Targa backdated to 1973 RS specs with a 3.6 shoehorned in the back, 1959 Austin Healey Sprite (former SCCA H-Prod), 1995 BMW R1100RSL, 1971 & '72 BMW R75/5 "Toaster," Ural Tourist w/sidecar, 1949 Aeronca Sedan / QB |
The starting experience in my "new to me S2000" is quite like my Honda snow blower...turn the key and push the start button. But seriously, as much as I like the S2000, I think it is a marketing gimmick.
I don't get why the manufacturers would add an additional step to starting the car.
Pointless. I was aftermarket 'starter buttons' in the Mini catalog. Quite silly!
'85 Defender 90 V8 Station Wagon (mine), ‘16 Mini Cooper S Countryman All4, ‘79 Mini Moke Californian (hers). '83 SC Coupe SOLD '96 Carrera 4 Coupe SOLD '89 Carrera Targa SOLD |
RETIRED
Marketing.....
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
19 years and 17k posts...
I like the pushbutton start on my MazdaSpeed3, it's pointless, but it's different. After all cars have it, it will be just like everything else...
Art Zasadny 1974 Porsche 911 Targa "Helga" (Sold, back home in Germany) Learning the bass guitar Driving Ford company cars now... www.ford.com |
<insert witty title here>
I suppose it's one less thing to fail - after just replacing an ignition switch in my 911 and a boxster, it's a pretty expensive and common thing to break. But I agree, it's just mostly the "cool" factor.
Current: 1987 911 cabrio Past: 1972 911t 3.0, 1986 911, 1983 944, 1999 Boxster |
Unregistered
IT MAKES THE CARS HARDER TO STEAL!
I thought that was well known. before a slide hammer with a sheet metal screw was all it took to jack a car, now it takes a computer chip built into a special keyfob. |
Slackerous Maximus
I love the Lexus system. Just walk up with the the keyfob in your pocket, touch the handle and it opens. Get in, push the start button, go. Seamless.
2022 Royal Enfield Interceptor 2012 Harley Davidson Road King 2014 Cayman S, PDK Mercedes E350 family truckster Steam locomotive. Yes, you read that right. |
Unregistered
And it's easy to make millions of combinations with the puter chip, with conventional keys there were maybe thousands? Maybe less?
Detached Member
Unlocks the door by me just touching the handle with my hand, while the key is in my pocket. You're right, $200 for replacements.
Hugh Last edited by Hugh R; 09-18-2010 at 05:53 PM.. |
83 911 Production Cab #10
I bought my wife a Mini (Cooper) which is equipped with the push button Ignition.
Actually its pretty good and the car key which you don't really need slip in the fob that you put in the dash before pushing the start bottom. One plus is that there is no key showing meaning that there is no key scratching the paint around the door handle. Now the thing that pissed me off (maybe I should read the book but apparently it's the same for all BMW) is that you can not put the *&^%$# car in neutral without starting the car ![]() ![]()
Who Will Live... Will See ![]() ![]() ![]() 83 911 Production Cab #10, Slightly Modified: Unslanted, 3.2, PMO EFI, TECgt, CE 911 CAM Sync / Pulley / Wires, SSI, Dansk Sport 2/2, 17" Euromeister, CKO GT3 Seats, Going SOK Super Charger Last edited by JJ 911SC; 09-18-2010 at 06:25 PM.. Reason: Got mixtup beteen Ignition and Start!!! See post # 18 |
See how the subject has morphed from the original"Push button Ignition" --to "Push button Start" ----They are different.
2010 Cayman S - 12-2020 - 2014 MINI Cooper S Coupe - 05-17 - 05-21 1989 944S2 - 06-01 - 01-14 Carpe Viam. <>< |
Who Will Live... Will See ![]() ![]() ![]() 83 911 Production Cab #10, Slightly Modified: Unslanted, 3.2, PMO EFI, TECgt, CE 911 CAM Sync / Pulley / Wires, SSI, Dansk Sport 2/2, 17" Euromeister, CKO GT3 Seats, Going SOK Super Charger |
