Senior Member
Boot Rant
What's the world coming to? By the time I was twenty (this was around a quarter-century ago), I had paid the princely sum of $55 for a pair of "waffle stomper" hiking boots to wear through the slush of University of Idaho winters. Apparently, my feet have grown a half-size, making them probably too small. Darn shame, since it appears that boots of this quality and construction are unavailable now in our Solar System.
It looks like the best of the best of the best hiking boots available.........are lined with that bull**** "antimicrobial" fabric lining. Nobody.........and I mean NOBODY seems to make a fully leather lined hiking boot. Nobody. I should take pictures of these boots. They're admirable things. The padding between the leather outsole and leather insole is still supple, as is the padded, elasticized, wrinkled-leather ankle cuff. I'm not sure these boots even COULD be worn out. Maybe I'll take them to a shoe guy and see if he can make the toe area roomy enough. Since modern society appears to have forgotten how to make a quality hiking boot.
Man of Carbon Fiber (stronger than steel) Mocha 1978 911SC. "Coco" |
Formerly reformed
Fill them with bags of water and stick them in the freezer.
1968 911P (Paperweight) |
i'm just a cook
a little yellow tag on the bottom..
'Vibram' & weigh 20 lbs.. yup..they don't make those anymore.. Rika |
post a pic supe..you got me curious.
have a pro give them a stretch. not sure they can get a whole size, tho.
poof! gone |
Senior Member
Senior Member
Yup.
Senior Member
I think I will take their portrait. And yes, I think I will take them to a shoe guy and see what can be done. They need new soles anyway, which might stiffen them and straighten out the curve they've developed over the years. They're only a teensy bit too short........maybe.
i've had soles replaced. it has never worked well for me. the soles get all new and "leveled" but the insoles are still angled from my wacked out gait. it feels weird, and i end up tossing them.
poof! gone |
76' 911s Signature Edition |
![]() Supes would be smooth leather, these things are heavy.. Rika |
Red Wing Shoes
do some scrollin' http://www.redwingshoes.com/productresults.aspx?ProductType=Work%20Boots
Tru6 Restoration & Design |
You'll have to go with something a little more modern and they ain't $55.00
651 CERVINO Field Boots | Norwegian Welt | Zamberlan | Made in Italy
--------------------------------------------------------------------------- "There is nothing to be learned from the second kick of a mule" - Mark Twain |
Senior Member
Yes, they are very much like these, except in smooth leather. Where did you find the picture, Rika? These have the leather collar at the top, suggesting that they might be close to what I am hoping to find.
Senior Member
Senior Member
sent PM..
Rika |
::: MEINDL ::: Shoes for Actives ::: http://www.kenetrek.com/products.asp?dept=7 http://www.hermitshut.com/koalhu.html
76' 911s Signature Edition Last edited by enzo1; 09-20-2010 at 12:33 PM.. |
Control Group
You can also put on some thick socks, get boots wet, walk until they are dry.
Freezer trick is not as good. You can put rice in a sock, put it in the shoe, add water and that will stretch them too, but can split the seams easily too.
She was the kindest person I ever met |
Limmer Boot Inc.
![]() ![]() "The Mid-Weight is a balance between the durability of the Standard and the day-long comfort of the Light Weight." Use: off-trail; ideal for those who plan multi-level hikes on a variety of terrains Outer: 3mm top grain, chrome-tanned outer upper, crafted from a single piece of leather Lining: breathable all leather lining Shank/Innersole: full-length nylon shank and leather innersole Midsole: 5.5mm partially expanded rubber cushion midsole layer Outsole: 8mm Yellow Label sole Construction: Norwegian Welt (double stitch) Average weight per pair: 3.75 lbs Available sizes: Women's sizes 5 - 9.5,10 Men's sizes 5.5 - 11.5,12,13,14,15,16 Men's wide sizes 5.5 - 12,13,14,15,16 |
