-   -   Need Some Help With Classifcations in Processes... (http://forums.pelicanparts.com/off-topic-discussions/570434-need-some-help-classifcations-processes.html)
M.D. Holloway 10-18-2010 01:47 PM
Real general - looking for classifications for materials and special considerations that are found in process facilities:
Gas
  • Temperature
  • Flammability
  • Pressure Requirements
Liquid
  • Volatility
  • Melting/Freezing Temperature
  • Viscosity
  • Causticity
  • Acidity
  • Flammability
Slurry (Suspensions)
  • Composition
  • Viscosity
  • (all considerations from II depending on the substance of the liquid phase)
Powder
  • Grain Size
  • Flammability
  • Solid
  • Dimensions
  • Temperature
  • Mechanical Tolerance
Important considerations for all categories:
  • Reactivity
  • Radioactivity
  • Toxicity
  • Stability Conditions
What am I missing?
GH85Carrera 10-18-2010 01:52 PM
We all knew you need more class Mike. :rolleyes:
M.D. Holloway 10-18-2010 02:06 PM
Ouch!
NO GREASE FOR YOU!!!
sammyg2 10-18-2010 02:59 PM
specific gravity for the first two.
ODDJOB UNO 10-18-2010 03:04 PM
wheres the EMERGENCY EXIT?
M.D. Holloway 10-18-2010 08:13 PM
Come on now fellas, I know someone out there can add to this list of mine...
oldE 10-19-2010 04:59 AM
Mike,
Would hardness/abrasion characteristics be of a concern with movement of the slurry and/or powders?
Les
id10t 10-19-2010 05:14 AM
Originally Posted by oldE (Post 5623054)
Mike,
Les
And what about shape for powders? (assuming similar to reloading powder - flake, ball, stick, etc)
M.D. Holloway 10-19-2010 09:02 AM
Excellent! Hardness & morphology - very good. Conductivity as well as static elctrical discharge would be a concern as well.
What else?
widebody911 10-19-2010 09:43 AM
Taste?
IROC 10-19-2010 10:00 AM
For liquid, I assume you meant "boiling" temp and not "melting"...
crustychief 10-19-2010 12:53 PM
Flash point?
