-   -   Recommendations for induction top cookware (http://forums.pelicanparts.com/off-topic-discussions/570668-recommendations-induction-top-cookware.html)
gt350mike 10-19-2010 05:44 PM
I know, I'm in danger of losing my man-card but I have to ask. We've remodeled the kitchen with new granite counter tops, new sink and faucet, and a new induction cook top. As luck would have it, we only have one pan that will work on the cook top so I'm looking for any recommendations as to where to buy cookware and if you have a preferred brand. My wife found a 13-piece set by Calphalon for about $400 and I'm curious if I can find a better deal.
peppy 10-19-2010 06:19 PM
My man card is long gone.....I got The Emeril set for $199.
The sides are a bit thin, but the base heats nice and even and holds heat well.
Emeril Stainless Steel 10 Piece Cookware Set E934SA64
TimT 10-19-2010 06:24 PM
I bought Calphalon years ago, and have had the 4 1/2 qt sauce pan replaced twice because of "silvering" i.e. the anodizing erodes away, and raw aluminum is exposed.. Basically a cosmetic thing..
If I were to do it again I'd buy All-Clad, or some cookware that is the interior is stainless, exterior aluminum, or copper, or a tri-ply..
BeyGon 10-19-2010 06:24 PM
We got a set of Emeril a few years ago, I think they might be better now but I wouldn't buy what we got again. The layered copper bottom has separated on a couple of them.
azasadny 10-19-2010 07:41 PM
All Clad is the way to go!!
enzo1 10-19-2010 08:21 PM
I have All Clad, then I bought a Lodge pre-seasoned cast iron set.... the deal is with cast iron you can be really rough with it an don't have to worry about it. Cast iron is the way to go for REAL cooks.
MysticLlama 10-19-2010 08:24 PM
We have an induction cooktop.
Get the All Clad and be done with it. You need the standard ones, some of the copper ones aren't compatible.
We got a 5pc set (3 pans, 2 lids) around XMas last year for $300, another $100 would by you one or two more. Much better way to spend $400 IMO than on 13, half of which you'll hardly use.
Just because something will work doesn't mean it'll work well. We have some cheap to mid-range pans that came with the house and they don't get nearly as hot as the All Clads.
enzo1 10-19-2010 08:28 PM
I bought my All Clad 1/2 price 300 for 600 set after christmas at Dillards, fyi
MysticLlama 10-19-2010 08:29 PM
Here is the set: All-Clad Stainless Steel 5- Piece Set - Sur La Table
Amazon has a 7pc for slightly more, but I believe they are a bit smaller, this gets you a couple of good size starters.
gt350mike 10-20-2010 08:29 PM
Thanks for the info....I'll pass on everything and let her make the decision since she cooks 90% of the time.
