Gas home water heater
I have to replace the mixer faucet in the kitchen. Problem is it's the only one in the house with no shut off between the hot water tank and the faucet.
Question is: what's the best way to drain the tank so there is no water coming out!
Do I just shut of the cold to the tank & run the tap 'til it's empty?
Is the burner likely to start up? etc etc.
PS I hate messing with gas!
Old 11-15-2010, 02:23 PM
Turn the gas to pilot (the pilot burns but will not turn on.
Shut off the cold at the entrance to the house and open the faucets above you and on the sink.
Water will not run uphill.
Rick
88 Cab
Old 11-15-2010, 02:26 PM
Unregistered
sammyg2's Avatar
Oh one more thing, and it's called a hot water heater
(inside joke).
Old 11-15-2010, 02:58 PM
Make Bruins Great Again
Por_sha911's Avatar
Shouldn't it be called a cold water heater since you don't have to heat up hot water?
Joe
Old 11-15-2010, 03:06 PM
Registered lurker
red911sc's Avatar
There should be a drain on the tank - open this and crack a faucet. The faucet will allow air in. Otherwise it will not drain.
Jeff
'79 Widebody SC
Old 11-15-2010, 03:10 PM
Since he is not doing an soldering he should be able to deal with the residual water below the spout. Or open a hot faucet in the basement.
Rick
88 Cab
Old 11-15-2010, 04:28 PM
Just like the Trojan horse was actually a Greek horse.......!
Old 11-16-2010, 11:51 AM
Por_sha911's Avatar
Exactly. Also why do we drive on a parkway and park on a driveway?
Joe
Old 11-16-2010, 11:56 AM
