-   -   Need some more 1911 help. (http://forums.pelicanparts.com/off-topic-discussions/576258-need-some-more-1911-help.html)
Rick Lee 11-20-2010 01:57 PM
I can't post this on our local AZ gun BBS because I got this gun from a guy there and don't want him to think I'm accusing him of hiding an issue (yet). It's a very sweet loaded Springfield Champion. It was part of a trade and came with three Chip McCormick 8 round mags. I can't believe I didn't notice this while were doing the deal in a strip mall parking lot. But none of his or my mags make the slide stay open without my pushing up on the slide catch. I just put 100 rounds through her today and the slide usually, but not always, stayed open after the last round was gone. But it won't stay open with I rack it back with an empty mag. What the hell causes this? The slide catch is not worn or rounded off and it takes plenty of force to release it, so I'm sure that area is fine. Will try to post some photos later when I clean her up.
onlycafe 11-20-2010 04:03 PM
trading spoons in a strip mall parking lot? was it at midnight?
Rick Lee 11-20-2010 04:20 PM
Parking lots are where I do a lot of my gun deals. Totally legal and customary in AZ. I traded an AR-15 and no one batted an eye at the other guy looking it over and aiming it in broad daylight.
Anyway, I think I found there problem. Here's the slide catch.
http://forums.pelicanparts.com/uploa...1290298739.jpg
Looks like there's a dimple on the inside of it, which is hanging up the spring action. I compared it to the slide catch on my other Springfield 1911, which did not have this dimple. I don't how it got there, as this gun is definitely not used enough to have developed this dimple from wear and it seems like there's no point in machining it there.
http://forums.pelicanparts.com/uploa...1290298830.jpg
id10t 11-20-2010 04:20 PM
It could be mags, but not likely. Check the slide lock... ok see you've done that. Compare w/ some other, see if the dimple is on the other or not.
ZLP 11-20-2010 07:23 PM
Call springfield, they have a lifetime warranty and will fix it.
MotoSook 11-20-2010 07:36 PM
Can't see the picture that well on my phone, but that dimple may catch the plunger enough to prevent it rising on mag spring pressure. If that's the case, a new one will fix it. Or put some solder in it and smooth it with a file.
Send the picture to SA and see if they'll send you a new one.
Rick Lee 11-20-2010 08:06 PM
Yes, plunger is the word I was looking for. I wanted a checkered slide stop anyway, so I ordered one. But I'll call Springfield up and ask about another replacement. I just can't see how this dimple was made. The gun looks new. It must take a ton of shooting to produce that dimple.
MotoSook 11-20-2010 08:47 PM
Or a bad casting with an air pocket in the right spot. Or does it look like the PO drilled it in there?
Rick Lee 11-20-2010 08:53 PM
Could be a casting air pocket. Why would anyone drill there? I'm wondering how I didn't notice this when we were doing the show and tell in the parking lot. The plunger spring seems super tight. My other Springfield's slide stop worked in the Champion perfectly.
jriera 11-21-2010 06:04 AM
Rick. bring it next time you are in Vegas ... I will fix it for you.
Rick Lee 11-21-2010 08:44 AM
I'll be there for SHOT in January and might come next week for Turkey Day. But I think I have this problem licked. Just gotta wait for the part to arrive.
jriera 11-21-2010 12:53 PM
Let me know if you come for Turkey day, some 'festivities' are in the making --> Vegasshooters 7th annual Turkey shoot November 27th 2010
You don't want to miss this one.
pitargue 11-21-2010 01:13 PM
that dimple is put there so the slide stop doesn't come out of its hole. It could be your plunger spring is a bit too hearty. While the slide stop is out, can you depress the corresponding plunger? Maybe there's some grit in there preventing the plunger from moving back and forth freely? Maybe blast it w/ some penetrating oil to clear it out?
chibone_914 11-22-2010 07:22 AM
1911
Your magazine springs are shot and are not strong enough to push the slide stop upwards. Order a set of Wolff springs from Brownells and you won't have any other issues.
Rick Lee 11-22-2010 07:23 AM
No, my mags are fine and work with my other 1911's just fine. In fact, I'm pretty sure the three Chip McCormick mags I got with the gun are almost new. The problem is that dimple in the slide stop.
dhoward 11-22-2010 11:17 AM
May just be an odd way to disable it. Most IDPA and IPSC shooters disable them on high-cap and sometimes single-stack guns.
Tim Hancock 11-22-2010 11:44 AM
Speaking of IDPA, while I have always loved 1911's, they are the most troublesome guns at IDPA events I go to. Very rarely does a Glock or XD hiccup, but many of the guys 1911's (whether plain Jane or the 2-3k variety) have issues which often blows a match for them with at least one effed up stage. I guess there is a reason the top guys at the nationals in CDP usually choose plastic guns.
Rick Lee 11-22-2010 11:47 AM
I've only done one IDPA shoot, but one of the guys there had a very bad night because his 1911 race gun hiccuped several times. This Springer is by far the most money I've ever had into a handgun and that troubles me, since my SIG's all cost less than half as much and always perform flawlessly.
mossguy 11-22-2010 11:53 AM
But Tim, the fact remains, that the 1911 is the only real gun! :D
Best,
Tom
dhoward 11-22-2010 11:53 AM
IMHO race-guns can be very finnickey. The trick is to keep them loose enough to function reliably. It took me a little while to figure out how loose is loose enough. I can still outshoot many of the younger guys with the $2500 guns with my 20 year old comped, fixed-sight rattle-gun. It's usually not the gun's fault. :)
