-   -   Stupid Question on how to use a multimeter (http://forums.pelicanparts.com/off-topic-discussions/577547-stupid-question-how-use-multimeter.html)
1973911s 11-28-2010 01:07 PM
My sprinkler system isn't working in the new house I moved into. I want to find out if I am getting any current and the solenoid.
So I have a meter, who do I use it?
I would assume I am looking to see if 24 volts was getting to the valve solenoid, but not sure what I set on the meter?
This is the one that I picked up at homedepot
http://ecx.images-amazon.com/images/...500_AA300_.jpg
Thanks for helping out the challenged.
Zeke 11-28-2010 01:22 PM
Set to DC volts to measure current. Use the higher setting than what you expect. Funny, I was testing some Malibu lights last week and was surprised that the low voltage from the transformer was actually AC 12v.
crustychief 11-28-2010 01:24 PM
If your transformer puts out 24VAC then turn it to 240 on the dial with the wavy line. If it is DC then use the same setting on the dial with the dashed and straight line.
I was typing while Milt posted.
Aurel 11-28-2010 01:25 PM
And plug the black wire in COM and red in VOhmA.
pwd72s 11-28-2010 01:26 PM
You'd want to set it on "VDC" in the voltage range you're looking for. Hard for me to make out the settings from your pic.
Suggestion: Craftsman part # 82303...a great little book:
Multitesters and their use for electrical testing.
Best 10 bucks for reference material I've ever spent.
James Brown 11-28-2010 02:28 PM
http://forums.pelicanparts.com/uploa...1290983183.jpg
get one of these it auto-ranges ac/dc volts. just select V and it figures out everything else. And get the book. The pen looking tool is handy to check outlets and switches that you want to work on so you don't zap yourself.
1973911s 11-28-2010 04:45 PM
Thanks guys, well I don't claim to know what I am doing. I found out the wands had covers on them, and that is why I wasn't getting any readings.
The good news is I figured out the common wire was broken, so a simple replacement of the wire and it all works. The good news is the past owner put PVC under the walkway, which made it easy to get the wire over to the valves. It also gave me the time to clean up the wires.
Thanks everyone.
VaSteve 11-28-2010 05:11 PM
Originally Posted by 1973911s (Post 5697854)
thanks guys, well i don't claim to know what i am doing. I found out the wands had covers on them, and that is why i wasn't getting any readings.
Ha ha ha ha :)
pwd72s 11-29-2010 12:14 AM
All's well that ends well. :)
