-   -   Question for the math/computer programmer/Excel geniuses (http://forums.pelicanparts.com/off-topic-discussions/577840-question-math-computer-programmer-excel-geniuses.html)
RWebb 11-30-2010 12:44 PM
Originally Posted by island911 (Post 5700378)
but he wants an Al Gore rhythm here.
for the poorly educated among you (like Islet) my al Gebra post was pun on the fact that we inherited algebra from the Arabs
they developed it during the peak of their civilization, ~~ 1,000 AD
Paco Anton 11-30-2010 12:48 PM
Post the 25 numbers and the amount paid and we'll figure it out.
RWebb 11-30-2010 12:51 PM
I agree with doing some manual "prototypes" of this in Excel.
There is indeed a min. set that will satisfy your criteria & I don't think it will be in the millions. real issue is how many min. sets are there?
why not sort the 25 entries from largest to smallest; then copy the smallest 24 to a new worksheet; then copy 23... etc.
work back from there & rule out the small #'s - that should give at least one result
if not, keep track of it, and add back the biggest #, drop the 2nd biggest;
Lather/Rinse/Repeat
it's a weird Q. for me right now b/c I'm reading a book on Richard Feynmann and how when he was at Los Alamos, they set up "circles of girls on calculating machines" and ran things thru those circles until they got answers - and a bomb
Paco Anton 11-30-2010 12:58 PM
I'd do a randomized approach.
1. Assign a random 0/1 value to each of the 25 Numbers
2. Add up the numbers with "1" value
3. If they add up to the goal value the you are set
4. If not cycle again
Leave the Excel woking all night and wake up to get the solution.
Post the numbers. I want to test my approach ;)
Aurel 11-30-2010 05:30 PM
I am assuming this is for business deductions on a tax return...Here is the quick and dirty way I would do it:
1. Sort the receipts in column A
2. Add the receipts is column B
3. If yer lucky, one of the sums will be the exact number
4. If not lucky, select the receipts that get closest to the total
5. Call it a day, let the IRS figure the details out :D.
Good thing I am not a CPA :rolleyes:.
LeeH 11-30-2010 07:28 PM
Amount paid from business checking = $1617.87
Charges:
486.87
32.48
247.84
9.64
27.19
30.00
79.36
28.17
119.53
26.79
530
141.65
11.4
40.83
53.15
36.93
11.40
84.25
44.39
58.25
328.53
175.82
182.44
332.67
3.87
-250.00 ... a $250 CREDIT from a return!
MBAtarga 11-30-2010 07:59 PM
so far through trial and error I'm as close as 0.02
Aurel 11-30-2010 08:00 PM
Here is your result:
486.87
32.48
247.84
9.64
27.19
30
79.36
28.17
119.53
26.79
530
That was easy my friend SmileWavy
MBAtarga 11-30-2010 08:08 PM
I concur. At least that's a possible solution.
Aurel 11-30-2010 08:14 PM
There might be other solutions, but since those were all grouped together on the top of the list, this has to be it.
Red88Carrera 11-30-2010 08:30 PM
Here's a link to an Excel template that does what you want. You will need the "Solver" add-in installed and enabled for it to work. I checked it out and it worked for me.
Excel Template - What Numbers In A Set Total A Target Value
Red88Carrera 11-30-2010 09:13 PM
Use the template I linked to and just let it run. It will run for about a minute.
486.87
27.19
79.36
28.17
530
11.4
40.83
11.4
44.39
175.82
182.44
There seems to be some funny accounting going on here. If you add up the first 11 items, they equal the exact amount paid on the business account. But if you look at my results, they also add up to the exact same amount. Do you want me to calculate the probability of that happening? Highly unlikely.
LeeH 11-30-2010 09:47 PM
I think Aurel has it! She paid the balance toward the end of the month, but before the end of the statement period, so several of the later charges actually happened after my client made her payment.
I sent her a note asking which charges were tied to this payment. I'd expect she'll be able to confirm this eventually.
Hodgey 12-01-2010 08:18 PM
....use the Excel add-in programme called 'solver'....
easy peasy, lemon squeezy.......
