:eek: |
Here's some more.
Ohm's Law Calculators has a calculator for figuring out total power requirements. I don't know what the "% over peak" standard is(mabye 20%)? Bigger is always better for future needs. American Wire Gauge table and AWG Electrical Current Load Limits with skin depth frequencies has some info on resistance drop over distance. There is a difference between interior-rated and exteriour-rated wiring. Some can be directly buried and some are required to be enclosed in a conduit. For safety, I'd recommend the conduit anyways. Better double-check wire type and burying depth with the city before buying anything. +1 on telephone/cable or leaving a sacrificial pull-wire for later needs. |
I did run Al. into the house from the breaker in the garage too. Used a 100 amp breaker at the main panel and for the main breaker in the house. I did separate grounds at both buildings. Anyway, it looks like the OP has an electrician and he should be OK. What were we talking about anyway? |
Good point on the breaker. You don't want a 20amp breaker when the wire and outlet are rated for 15amp.
| All times are GMT -8. The time now is 06:43 AM. |
